  3. Gaming
  4. DVD burning question
18 Posts 10 Posters 1.2k Views
    i think in DVDshrink you can change the options...but im not sure havent burned a movie in a long ass time
      I dont know of any other way. When I'm finished, I just delete the file.
      • BlueSRT0483B Offline
        BlueSRT0483
        That's what I do; in face I'm copying/bruning some now..
        Just let it upload/burn to disc..
        I'm sure you can maybe do it from Drive 1 to Drive 2 like you want, but...
        Who knows, I figure this is the best way incase you want it on your computer too..
        2004 Dodge SRT-4
        ...Formerly "A853"...
          I use DVD Decryptor to rip the DVD, use DVD Shrink to edit the crap out and then burn from Shrink to Nero. Works great....but it does leave a data file behind, which can be a good or bad thing...
            BlueSRT0483
            What about DVDs that automatically pop up & give you options to view websites and stuff.
            There's one that I can use Shrink on.. Stealth is the movie..
            2004 Dodge SRT-4
              No you cannot do that. Burn on the fly is not possible. Here's why.
              Most Commercial DVDs are DVD9, the DVD's we burn that aren't Dual Layer are 4.7gb...
              DVDShrink actually re-encodes the files and then saves the output in to vobs... Man this shit is so simple compared to what it used to be back in the day using DeCSS and all that bullshit....
              So unlike CDs where the data stream can just be copied, there is actual information that has to be processed / encoded here, so no you cant do on the fly recording.
                stealth is copy protected......
                  BlueSRT0483
                  So wait; there is no way at all of copying the movie? yet anyways....
                  Poopie deal!
                  2004 Dodge SRT-4
                    There are ways but it gets considerably more complex then using DVDShrink...
                    http://www.vcdhelp.com
                    is your best resource
                    • uwatchnU Offline
                      uwatchnU Offline
                      uwatchn
                      I use the same thing but use DVD2one...works well ... I just delete the files when done
                      I couldn't copy that one either. First one i have found so far.
                        BlueSRT0483
                        well if anyone finds out what to use on that one, post it up 🙂
                        2004 Dodge SRT-4
                        • HoboKameraH Offline
                          HoboKameraH Offline
                          HoboKamera
                          you said you were using nero. if you're using nero 6 or 7, you don't need dvd shrink. just use dvd decryptor to rip all the files of the DVD to a folder on your hard drive. then use Nero Recode to re-encode the DVD and take out the parts you don't like. I personally think it works much better then dvd-shrink. And nero recode is updated all the time, unlike dvd-shrink which hasn't been updated in a long ass time. And with nero recode, you can save the file as an iso/nrg image on your hard drive for later burning. Or if you have a dual layer DVD burner, you can just do a 1:1 copy of the dvd, which means you can just do a straight copy. No ripping, converting, etc.
                          '05 Neon
                          • Legacy99L Offline
                            Legacy99L Offline
                            Legacy99
                            Doesn't DVD Decryptor work on Stealth?
                              Nope......
                                Stealth and Unleashed both don't copy, there are several ways to get around it but its not worth the time
                                • Legacy99L Offline
                                  Legacy99L Offline
                                  Legacy99
                                  Well you can always just dl stealth...
                                    BlueSRT0483
                                    well if those are the only two vids, i think i'm not going to cry over it..
                                    2004 Dodge SRT-4
