  4. Opinions needed. If you have one, tell me.
50 Posts 15 Posters 1.6k Views
  • D Offline
    D Offline
    dynotune
    Heads/Cam all the way!!! If you got the jack do like a 393 lower half and some trick flow heads or if you don't, just go with the ported heads/ cam. They make great power, and coupled with the right gears, the extra RPMs help ALOT. Add a little spray on top and you'll be well into the 500 club. Fuel economy isn't too terrible bad (I have 427 LS1s getting 29.5 MPG in C5s)- you should still be able to expect 18-21. Labor is intense although- I highly suggest yanking the mo to do the swap. While your in there, you should at least do rods/ pistons while you can. F-bodies are a bitch to work on, but the results can turn out impressive when done. ATI kits are nice as well (I know a guy who can hook you up...) but depending on how far you want to go, you'll have to get forged internals anyway. N2O is harder on things (look at your bearings after spray vs. supercharge/ turbocharging) but it's pretty good bang for the buck especially if you already have the setup. DO NOT go above 12:1 or use race gas- it's not necessary at all. Every pt of compression usually nets only about 4% add'l power- not hardly worth running race gas. My $.02
    DynoTune Speed & Performance
    Mobile chassis dyno service
    www.dynotuneusa.com
    (605) 753-1101
    • camzaro28C Offline
      camzaro28C Offline
      camzaro28
      well wrx guy if i was to tell u something about ur wrx, i wouldnt know to much at all to tell u. but just do some research for urself on some camaro LT1 boards and see how many guys are running blower/turbos, and see how many of them lasted. im not blowing smoke up ur ass about it.
      and yeah i know it harms the rings. but like i said it takes time and alot of spray of course, on a good running motor.
      sean go with H/C setup, dont venture into boost with an LT1 unless u can afford it twice. just a mild setup will net u 380ish. then spray 100 on top of it, and it will be a healthy motor.
      jig 4 prez
      • Sweet-WRX-LovinS Offline
        Sweet-WRX-Lovin
        I'm from the wrong school I guess on this one. If you can't go all the way, then go cheap as possible and wait till that shizat blows up and do it again. My old man got second in the NATIONAL CHAMPIONSHIPS two years in a row on $500 or less motors. But he does know what he is doing and labor is free. If I were you I would go all out, but that is me. I wouldn't have bought a 34k+ car if I didn't believe in this philosophy. (sorry about spelling, been drinking, imagine that) And I don't care about research on boards, I've seen the real thing in real life for as long as I've been alive, if you do it RIGHT, there isn't anything to worry about. And that means covering all your bases.
        One time...
          camzaro28C Offline
          camzaro28
          i see me and u have a different philosphy. and i will go from what other guys that drive the same car as me do. i will let the guys that have the money do the trial and error and see what works. and what doesnt is a blower/turbo on a LT1.
          if i am gonna do something, i will do my best to do it right the first time. and i definetly wont do something like a 3-5k investment if it hasnt worked for others
          so ur saying go blower, because it is double the price??
          jig 4 prez
          • 94NDTA9 Offline
            94NDTA9 Offline
            Sweet-WRX-Lovin wrote:
            Well, you are asking the wrong person here. Butt, and yes I said butt, my old man is a machinest and race car driver for over 30 years, I personally would build a cheap as possible motor running super high compresion (cheaper over the long run vs. a supercharger) but running race gas. If you aren't willing to make this sacrifice I have no hope for you. And BS on the supercharger rebuilding at 20K miles. If you have an ass monkey tunning your car maybe. I have no idea what I'm doing compared to my old man and I could get WAY more mileage out of that.
            No offense, but I'm going to wait till you havn't been drinking to corect yourself or retract your statement.
            There are plenty of machinests and expereinced racers running LT1's. 20K on a STOCK INTERNAL LT1 is pretty much the norm, for people running boost of equal knowledge level, or more, of what your old man knows.
            I'm sorry, but you are simply in the wrong on this.
              Sweet-WRX-Lovin
              Same car has nothing to do with it. I'm saying blower not because it is simply twice the price or something like that, but because it has a sweet payoff if done right. Plus the payoffs are expandable as you upgrade your engine, especially on a V8. It's exponetial compared to a four cylinder of course. And if you scorch the motor it is very cheap to rebuild it with just a service manual, a decent set of wrenches, a torque wrench, yes a few other odds and ends, and some patience. I've built A LOT (more than a hundred) of V8s by hand, it's not that hard. If you are even considering going a little nuts or all out. V8s are cheap to rebuild unless you are going absolutely crazy (rollercams, ported heads, high rise intakes, valve magic, and exotic deck, head, rod, or crank work, etc.). All I'm really saying is seriously consider what you are really trying for in the end and put NO time limits on reaching those goals. If it takes longer to save up for a charger so what. What you have in the end is well worth it. I don't plan on making major power with my car for a LONG time. If it takes me 10 years so what, I'll have it sooner or later. I guess my opinion is don't sell yourself short for short term power when you can use most of that money towards a real big power setup in the relatively near future. Anyway this has probably gotten out of hand so go with whatever you feel is best.
              One time...
                Sweet-WRX-Lovin
                Me drinking has nothing to do with this. My old man is a fucking GENIUS (and I am being actually humble) when it comes to mechanical things of any kind. I'd put him against the absolute best in the WORLD at anything to do with engines. I could care less what some part time free lance mechanics (or full time for that matter) think or experience with engines. He could get it to work, and work well for a long time. Lecture all you think you need to. I gotta go to Denny's now, be back to talk about this later 🙂
                One time...
                • 94NDTA9 Offline
                  94NDTA9 Offline
                  You see to be missing what I am trying to acheive. Getting a blowe now woyuld be down right stupid.
                  A. I would need a smaller blower that would need to be upgraded IF/WHEN I deicde to make a good amount of power, new units are NOT cheap.
                  B. Said blower would cost MORE than the set up I would be going with, with about equal the power.
                  C. H/C set ups are expandable as well, without the hassle of having a blower/worrying about a rebuild WHEN I CAN'T AFFORD IT!
                  D. you seem to be missing the point where MY ENGINE come with a really high compression ratio stock/ lightweight, non boost freindly internals. It is not a standard SBC. Boost on a STOCK LT1 basically reulsts in constant waiting till WHEN it blows, not if it blows, even when dyno tuned extensivly. This does NOT equate good for a DD.
                  I don't want to be rebuilding my engine with crap $500 parts over and over again. It will be a daily summer driver for now. A blower is not in any way shape or form, a good decision for me at this point, no matter how you look at it.
                  • 94NDTA9 Offline
                    94NDTA9 Offline
                    I guess there is no hope for you. You foot the bills for the rebuild, and I'll pay to blow it.
                    Not all of us can have a HOLIER THAN THOU, JOHN FORCE SUCK MY CACK father. What are you trying to say? I should boost it because YOUR father could tune it right and make it work, even though YOUR FATHER IS A GOD AMONGST MECHANICS?
                    What does that leave me, the average joe, 99% of the world who can't hold a candle to your father, with?
                    You make no sense whatsoever.
                      What schultzy is saying is that you should just stick with what you have right now until you can afford the big power instead of spending more money for a small upgrade(well actually in this case you lose power) hes not telling you to buy a blower right now and shit hes telling you to save your money for when you CAN afford it...and seriously his father is pretty respected...
                      • 94NDTA9 Offline
                        94NDTA9 Offline
                        I allready know his father is respected, I have heard great thing about him, but just becuase HE could get an LT1 with high comp to safely run boost for a long time doesn't mean that I , or 95% of the F-body community can.
                        I agree totally with saving till I can afford big power. However, what he is suggesting is a large leap/commitment that would require constant money to be on hand for this project. I am trying to keep this proeject reliable for now till I can afford to be throwing tons of money at it. Going through the pharmacy program is not cheap, especially when I'M the one footing all the bill. I would rather have a car that I can enjoy in the summer, that is in good condition, and is faster than 99% of the cars on the road. I've had constant work on it for 2 years, I would like to enjoy this car the way it is for once.
                        Yes nitrous isn't super reliable, yes a high reving H/C set up isn't too reliable either, but both are MUCH more reliable than any for of boost on the car.
                          yup exactly...i think you just answered your own question...save your money until you can actually go big...you have decent power now so why spend more to lose power? kinda makes sense to me...just wait until the time is right to drop big bank on your car so you can do it right...dont just do somethin small now...remember its always hard to save up for your big goal if you keep spending the money you have on small things that arent needed at the time...
                          • 94NDTA9 Offline
                            94NDTA9 Offline
                            I agree with you totally. So far, I've only been buying the best of the best as far as purchases go. I am awesome at saving up money (bought this car, cash, when I was 16 working on 5.15 an hour). Everything purchase for it is the best you can get.
                            If I were to go all out with this car, I don't know IF I would go with nitrous, I probably would go FI. Either way, ported heads and a new cam/valvetrain fit into that equation.
                            Maybe I should just leave the nitrous, save up for a long time AGAIN and get a NICE h/c/valvetrain set up, and spray a small shot (50 or so) till I can afford to rebuild it.
                              it really makes more sense...who cares you run nitrous...your car makes good power now so why spend money until you find somethin you REALLY want(that makes more power or the same)...its not worth it to do things twice...it just seems wasteful buying parts twice...
                              • 9 Offline
                                9 Offline
                                97lt1
                                A boosted LT1 on stock bottom end will not last longer than 20-30,000 miles.
                                I say start putting money away until you fiqure out what you want to do.
                                I think I'm going to start saving up for a H/C package along which a 396 short block.
                                • 94NDTA9 Offline
                                  94NDTA9 Offline
                                  I guess. But If I sold the nitrous, I probably would want to do FI if I upgraded, simply because I would like to try something different.
                                  I see your point, I guess I just wanted a car that would be fun to drive off the bottle as well as on.
                                  Better start saving/selling kidneys.
                                    Sweet-WRX-Lovin
                                    Sorry if I came off on the holier than thou, john force suck my cack wagon, just trying to share the little I know from learning from my dad and through my own experiences. Good luck on your build, I'm sure it'll be fantastic. Thanx Tony. And yes, he would be considered a God if he desired that kind of recognition you dumb fuck. Jesus Christ. Save your God Damn money and get something worth while. I don't give a fuck how much the pharmacy programs costs, if you don't have the money to get what you really want in the long run , then don't fuckin' spend any. There, did that spell it out better? Opinion wanted, opinion stated. Best of luck.
                                    One time...
                                      Wow, settle down there chief.
                                      • 94NDTA9 Offline
                                        94NDTA9 Offline
                                        Still drunk or do you just get angry very easily?
                                        Did you read my posts at ALL?
                                        If I make the words larger, will you then actually understand what I'm saying?
                                        Should we give that a try? Peachy. Here it goes.
                                        PORTED HEADS, A NEW CAM, AND AN UPGRADED VALVETRAIN ARE SOMETHING WORTH WHILE. IT WOULD BE STUPID TO REBUILD AN ENGINE (IN THE LONG RUN, BECUASE THATS ALL YOU SEEM TO BE FOCUSING ON) AND LEAVE THESE ASPECTS STOCK. IT WOULD YEILD THE SAME HP, FOR CHEAPER, THAN A SUPERCHARGER SYTEM, AND WOULDN'T BE AS HARD ON MY ENGINE.
                                        SO YOUR OPINION IS, TO SPEND MORE MONEY ON A SUPERCHARGER SYSTEM THAT MOVES VERY LITTLE AIR, WILL ALMOST REQUIRE A FULL REBUID SOON (OF COURSE, UNLESS YOU OR YOUR FATHER OWNED THE CAR, IT'S A SHAME THEY DON'T), AND WILL REQUIRE AN UPGRADE IN THE NOT TO DISTANT FUTURE.
                                        There, that said, I'm sorry we had to argue. Can you hug me now? 😮
                                        I see your opinion, it just is not the best option to spend more money on a system that is harder on my engine, and will need a certain upgrade in the future.
                                        The system I would be going with would only need a cam upgrade to lower the comp, wich is only a couple hundred dollars as apposed to a $1000+ unit.
                                          camzaro28C Offline
                                          camzaro28
                                          not one of his options
                                          stated he didnt want to go all out
                                          he stated he dont have the money to do it right
                                          his goals are 400RW with reliability!
                                          um, he stated @ 400RW is what he wanted, u r the one telling him to go all out
                                          so how many 500$ motors with blowers actually made it to running status?
                                          jig 4 prez
