WTB: 200x2 amp
buy a lanzer brand new for $150 bucks
amicheze wrote:
i have an old 240x4 rampage amp. definitely not top of the line but it gets the job done. model amp-604. 25 bucks.
I'm sure it gets the job done, but I have had some previous bad luck with rampage, so I will check with the person I'm building the stereo for and see what they think.92BlackTT wrote:
Do you know what model is 150 brand new? and its lanzar, isnt it? Or are u talking about a different brand? -
How much are you looking to spend Jason? I know we discussed a few models via PM. I has have a used Lanzar 1800D for sale (used 3 months) for $200, MSRP on it is $500.
1 x 400 Watts RMS at 4 Ohms
1 x 800 Watts Max at 2 Ohms
1 x 1200 Watts Max at 1.3 Ohms Bridged
Class-D Design
Remote Subwoofer Bass Control
Mono Block Subwoofer Amplifier
1 Ohm Stereo Stable
MOSFET Power Supply
PMW (Pulse-Width-Modulation) System
Glass Epoxy PCB w/SMD Technology
Gold RCA Inputs
Custom Terminal Block for Speaker Connection
Thermal, Overload & Short Protection
Variable Subsonic Filter (15Hz-40Hz, 24dB/Octave)
Variable Lowpass Filter (20Hz-250Hz, 24dB/Octave)
Phase Control 0~180°
Remote Bass Control
Input Impedance: 10k Ohms
Soft Turn On/Off
Heavy Duty Power Coated Heatsink
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
Dimensions: 10.25”W x 2”H x 15”L -
that amp that tjamz is talkin about is basically a lanzar 1200d with a different heat sink...very good amp...its around 1200-1300 watts rms @ 1 ohm (has been bench tested at this)...a lot for 2 10's (depending on what you have)...but you can always turn it down too...but brand new on ebay they are $220 or so shipped...thats my .02...later
i have a rockford punch 200x2 - $75
