  3. Wanted Ads
  4. CHEAP amp
CHEAP amp
10 Posts 5 Posters 1.3k Views
  • youngin2nrY Offline
    youngin2nrY Offline
    youngin2nr
    Like the title says cheap amplifier that i can use just until I save to buy a "nice" system. It will be powering a 1000w audiobahn 12" sub. Dont need the sub to set records so i could live with like a 260w amp just for now. Also would need some wires to install it. And if someone on here knows how to install i could use you to.
    UNDER $100.
    Like I said NOTHING SPECIAL!
    -Nick
    :3gears: -> :drink: -> :poon:
    • g2gsG Offline
      g2gsG Offline
      g2gs
      i got a punch amp its the second smallest one they make but should still sound good ill get the model # if interested
        youngin2nrY Offline
        youngin2nr
        how much? What wattage? Channels?
        • krzydrftr93K Offline
          krzydrftr93
          Did that amp work I sold you or whats up with that?
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            burnteclipse
            i have a 400 watt colbalt that worked really well when i had it installed until something went out in it. someone told me it was like 25 bucks. ill let you have it for 40 bucks....let me know
              youngin2nrY Offline
              youngin2nr
              Yeah it worked great. I am using it for another small sub i have.
              • g2gsG Offline
                g2gsG Offline
                g2gs
                ill get the specs up on that amp tonight i forgot it so i counldnt get them up today
                  krzydrftr93
                  Alright, sweet
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                  • g2gsG Offline
                    g2gsG Offline
                    g2gs
                    the amp i got is a punch 250a2 rated at 62.5x2 at 4ohms and 125x2 at 2ohms. let me know if you are interested.
                      aliengotpsi
                      I still have that 400 watt amp( rockford fosgate)
                      Kevin Smith
                      Straightlinedetailing.com
