  4. anyone figure out whats going on in this pic?
24 Posts 12 Posters 883 Views
  • D Offline
    D Offline
    dynotune
    I got cut short, but I know the 2.3L fords have 8 plugs too, as do the new hemi's (2 per cyl)
    DynoTune Speed & Performance
    Mobile chassis dyno service
    www.dynotuneusa.com
    (605) 753-1101
    • D Offline
      D Offline
      dynotune
      Wasted sparkmeans the plug is fired on the NON compression stroke, some use wasted spark w/ one coil, some use whole different ignition "system" for the "wasted" spark. The new hemi has 16 spark plugs, eight fire on one revolution, eight on the other.
      www.dynotuneusa.com
      (605) 753-1101
      • 91nbtsi9 Offline
        91nbtsi9 Offline
        slowvo wrote:
        wasted spark and dual plugs/cylinder are different....
        waste spark just means that there is 1 coil for 2 clyinders....
        Also, if those 4 wires are grounded...it would effect the spark for the cylinder that the other wire is going to....the engine wouldnt run....
        if the wires REALLY dont go anywhere....then why are they acually there? this setup would work with those coils......if there were only 4 wires....
        What happens when you have a wasted spark system and you take one wire off? It arcs at the coil, through the wire boot, because that is less resistance than jumping the 2 feet to the block. If what you are saying is true, all the current would go through the connected wire(path of least resistance) and not arc on the open terminal.
        Here is why...
        The current only flows one direction. If the other wire isn't grounded, returning current will try to arc back to the terminal on the coil and have a lot of resistance. Where as if the un-used plug wire is grouned, it just provides a return path for the current. The current goes out one terminal and jumps the plug gap and goes into the block and then is supposed to jump the companion cylinders plug gap and go back to the coil. So, if the other wire was just grounded, it would provide an easier path back to the coil. It does this because it is an induced current from the collapsing magnetic field in the primary side of the coil. Since it is DC, the current will only flow one way. The coils are setup so that the magnetic field causes the current to go in the direction of the spark plug that you want to fire, so that you get the most voltage in the place the engine needs it. All it needs is a complete circuit. The un-used return wire will complete the circuit.
        I maybe wrong but I think I am right. 😉
          that sounds right Nate but its been awhile since i've actually thought about that stuff
            slowvo
              I could be wrong but don't funny cars and top fuel dragsters run 2 wires per cylinder, I could swear I've seen it or at least heard about it before. Not sure of the reason unless it's for the "wasted spark" your talking about. I always thought they where for a backup, a redundant system, so if one fails there's one to back it up.
              I never got into the more advanced workings of ignition systems, I put in my msd box and looked a few schematics to trace wires but that's the extent of my knowledge. 🙂
                the book nate just wrote is true.. but that doesnt change the fact that the car is dumb.
                • 91nbtsi9 Offline
                  91nbtsi9 Offline
                  Lol. That car is pretty stupid.
                  I do not think that is related. I believe the ones you are thinking of have 2 sets of plugs, and pretty much two ignition systems.
                    does that motor use a hall switch? i dont htink you can use a coil per cylinder with one unless you had two triggers?
                    • harwood39H Offline
                      harwood39H Offline
                      harwood39
                      ^^^i thaught they had 2 ignition systems also, they do have 2 distributors
                      2730 5th Ave S. Unit C
                      Fargo, ND 58103
                      701-429-3686
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        I am pretty sure that car is using megasquirt with a ford EDIS ignition system. You can see the trigger wheel on the cam sprocket and the pickup. It is possible to run a 4 cylinder with sequential ignition with that setup.
                        EDIT: I take that back, it is not using a Ford setup. But, it is using some type of ignition system with a trigger wheel and VR sensor...
                        I am not sure which system, but it surely could support the COP.
                          now i feel dumb
                            harwood39H Offline
                            harwood39
                            wow, i think all of us feel dumb now, i was just concentrating on the wires and didnt notice it. How, idk, cause its pretty noticeable
                            Fargo, ND 58103
                            701-429-3686
