  3. Wanted Ads
  4. AWD rear plate
AWD rear plate
10 Posts 4 Posters 645 Views
    I need the plate that bolts the tranny to the motor for my eclipse..
    whether its called a flex plate, rear plate, wahtever it is...
    it has to be for a AWD..
    or nick or kevin if you can find mine let me know.
      also need the part of the top motor mount that bolts to the blocck...
      also a 97-99 t-case
      and the lower part of the transmission mount...
      i'm sure theres more to come..
      or if you have a 2g that you want to sell let me know.
        aliengotpsi
        hmm I will look around..
        Kevin Smith
        Straightlinedetailing.com
          I will sell you my car....
            wasnt there just a thread about whoring the classified wanted ads???
            and your a admin wtf...jk
              I am such a whore.....:p
              • 9 Offline
                9 Offline
                95TsiAWD
                I had to order both of those for mine. I could find you the part numbers off my slips if you need. PM me if you want them. The mount was about $70 i think (came with the belt bearing roller thingy) and the other flywheel shield plate was 20ish if I remember right.
                95 TSi AWD
                Old Turbo #'s
                522whp/414wtq
                [email protected]
                11.3@129mph
                Procharged 99 Corvette
                95 LS6 Mustang
                01 300m
                06 Suzuki LTR-450
                • 9 Offline
                  9 Offline
                  95TsiAWD
                  To clarify, are you taking about the piece between the tranny and engine that the starter goes through as well? Or the piece at the bottom of the tranny that protects rocks from getting into the flywheel/clutch?
                  95 TSi AWD
                  Old Turbo #'s
                  522whp/414wtq
                  [email protected]
                  11.3@129mph
                  95 LS6 Mustang
                  01 300m
                  06 Suzuki LTR-450
                    the piece that goes between tranny and engine that the starter bolts to yes..
                    where did you order the pieces from??
                    I've had a 6 bolt in my car before so i should have that mount somewhere along with that plate!!!!
                      anyone have any of these??
