  4. Door Unlock/Lock remote
8 Posts 5 Posters 502 Views
  • youngin2nrY Offline
    youngin2nrY Offline
    youngin2nr
    I dont know what they are called if there is no autostart. But I am looking to get a remote that will unlock and lock my car. Someone said a key "fob" or something like that but im not sure. Nothin fancy but i am just getting nervous about the shit getting stolen in my neihgborhood.(being that my door locks are the ones where the only way you can lock it is by pushing the lock down from the inside) I know that Tjamz sells the autostart ones but i dont want an autostart. Where could i get a decent one for real cheap? Anyone know?
    Nick
    :3gears: -> :drink: -> :poon:
      youngin2nrY Offline
      youngin2nr
      keyless entry
      Thats what it is.
      • 3_Series3 Offline
        3_Series3 Offline
        3_Series
        Just get an alarm system, then you get the security you want and the convienence of remote unlock.
        2002 Subaru Legacy
        1993 BMW 325i (sold)
          youngin2nrY Offline
          youngin2nr
          Thing is that is more expensive
            Keyless entry provides ZERO protection against theft. ZERO, ZIP, ZILCH, NADA
            get an alarm and then have someone competent install it, otherwise it will be a worthless noise maker for anyone except the person trying to steal the car/parts
            • TakeYourTopOffT Offline
              TakeYourTopOff
              Key fob is the piece of the keyless entry that will control the locks it also is what controls an astro start or other remote starters and or alarms.... alarms will only go so far if you get a theft that know's what they are doing it won't stop them but i'm guessing most of the theft that goes on around here is just dumb asses with no respect for OPP
              legacy image legacy image
              Personal Web Site
              • krzydrftr93K Offline
                krzydrftr93
                Why dont you stick the key in the hole after door is shut and lock it or if you push down the lock then hold the handle in open position and shut it the lock should stay or it does on most cars.
                Matt
                92 Civic HB
                JDM d15b w/14b@8psi
                  FWIW, I can do a very basic alarm w/ keyless entry for ~$150 installed...maybe a bit more if I need to add an actuator to control the drivers door lock...$175 installed then.
