  4. CEL after d16y8 motor swap... can't pull a code...
11 Posts 4 Posters 429 Views
    Hey guys quick question. Over the weekend we put a d16y8 into my 92 hatch. The motor starts and runs pretty well. However, I have a check engine light haunting me. The check engine light won't come on until the car has been running for like 5-10 seconds, and if I try to pull the code it just stays solid. One thing you should know if I'm running open header until I get my exhaust done on monday. Would that be why, or what else can I check?
      i wouldnt think not having an exhust wouldn't though a code. is everything connected right grounds ect. did you have to change anything on harnesses.
      could there be a bad sensor somewhere?
        You got the 4 wire 02 sensor in there or just the 1 wire?
          could there be bad sensor somewhere? yeah I suppose, but it's kinda vague....
          I think it's the 4 wire tufte, but I'll have to check.
            it could very well be the o2 sensor, it was kinda messed up (cockeyed) from when it was in the bed of troy's truck when it got hit. that was one of the other things I was thinking about, but wanted to get other feedback.
              If the light turns off and you cant pull the code then really what is the problem though? If you cant pull the code there is none to be pulled esp if the light turns itself off.
                the light is on the whole time the car is running.... after the 5-10 second delay. it just clears itself each time. if the motor is not running the cel is gone. you know how usually you can just pull the cel by having the key in the on position. I don't know if I'm making sense here.
                • darkelvisD Offline
                  darkelvisD Offline
                  darkelvis
                  with the solid CEL does the car rev past 3K?
                    I don't know... I haven't been driving it so far, I'll have to check tomorrow.
                      You cant just turn the key and pull the code, you need jump the wires togethjer to put it in limp mode. I put a toggle switch for those 2 wires right above the ECU, just flip the switch and the light will stay on solid then flash the codes.
                        n/m guys I got it figured out.... there was just a loose connection on the toggle switch... repaired that connection, and it pulled just fine. CEL #41... Primary Oxygen Sensor heater...
