  4. Project RWD
Project RWD
60 Posts 20 Posters 5.1k Views
    • JOHNDEEREJ Offline
      JOHNDEEREJ Offline
      JOHNDEERE
      Im gonna start with the turbo 350 and a toyota truck rear end!
      • My NOvaM Offline
        My NOvaM Offline
        My NOva
        PSiedTSi wrote:
        i dont think hes using the TH350....i think he might using a powerglide?? powerglides are the ultimate
        i can agree ihave a stage upgrade in my two speed Powerglide the shift is so smooth. somtimes though i do wish i had the TH350 for the that extra kick i second gear I would go with the powerglide
        Hey Tina come get some hamm
          With a v8 or even a 6cyl, I would go with a powerglide. But with only a 2.0 4cyl. I think that a three speed would better suit his needs. Alot better chance of being in the powerband all be it one extra shift. But it's alot less to worry about than the 5 speed he's used to. And no more missed shifts.
            Also hopfully no more broken trannys...
              As long as he gets the converter right, it will be fine with 2 speeds. My car never goes below 7000rpm the whole pass at the strip, so there is no worry about falling out of the powerband.
              • harwood39H Offline
                harwood39H Offline
                harwood39
                hey, i have a turbo 400 in my 64 chevy pickup that is for sale, truck is shot, drive train and motor are in great shape. 327(many mods), posi rear end, turbo 400 trans, do have a rust free cab if someone does want it to restore instead.
                2730 5th Ave S. Unit C
                Fargo, ND 58103
                701-429-3686
                • W Offline
                  W Offline
                  Wizard
                  First:
                  The main reason most draggers use the powerglide is because it's lightweight, and the fact it takes very little power to turn. The TH350 while being 3 speeds, takes a considerable more power to operate and weighs over 100lbs more. The TH400 is a VERY heavy transmission and takes even more power to turn.
                  Buschur uses the powerglide in both his old back half and tube car. He also runs it in his Conquest racers. Bill Walls, Aaron Poe, etc. Many of the Supra guys run a powerglide too. Venom, Titan, Paul Efantes, etc.
                  Wiz
                  1992 GVR4 598/1000 Nile Black
                  1992 Tsi AWD
                  1982 Datsun KC 4x4
                  1990 Laser 2.0 AT NT
                  1994 ES 2.0L NT 5-spd
                    harwood39H Offline
                    harwood39
                    but the th400 is a very very strong transmission also. thats why its almost worth running it.
                    Fargo, ND 58103
                    701-429-3686
                      powerglide Is very very strong too!
                        yeah cause none of those others are strong :rolleyes:
                          Kevin was telling me he could get a deal though on the turbo tranny, is that the one he is going with then?
                            I agree with the fact that the powerglide robs ahelluva lot less power. But as far as weight goes, Theres only about 25lbs difference between the th350 and powerglide. plus usually, and I mean USUALLY, the turbo 350's are cheaper to build. I personally like the idea of shifting only once and like them both. As far as a th400, Well the cost too much to buy and build compared to the other two. They are very tough out of the box but do rob alot of power. Like 45hp in stock form. Given building it up will make that number decrease but a th350 usually robs between 25-35hp in stock form and the good ol shlushbox er, uh, powerglide robs even less. So if you do themath it's a no brainer. But I think kevins a cheap ass. JK!
                              How much more does this tranny weigh compare to the stock AWD transmission?
                                If I were to guess, I'd say about 75lbs. Now that's just a guess. Ive never lifted an awd trans but I have a fwd. The auto is alot heavier. But a small price to pay.
                                  yeah the awd tranny isnt really that bad...i can carry it myself with not much difficulty
                                  • My NOvaM Offline
                                    My NOvaM Offline
                                    My NOva
                                    The power glide Was at most empty 75 pounds Those trannys can a lot of punisment
                                      I weighed them side by side, no fluid and no converter. The glide was 101.5lb, the TH350 was 139.5lb.
                                        And there you have it. Thanks for clearing that up Dave. It's good to see that you are on the ball. I work at a junk yard have access to all the above trannies but am too lazy to weigh them all.
                                          Dave just breaks trannys so he has a bunch laying around.
                                          I'd really be interested in knowing how much my auto trans weighs, all I know is I can lift it and set it down a few feet away but that takes almost everything I have in me.
