  4. Ls1 RX7
Ls1 RX7
63 Posts 22 Posters 5.0k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    94NDTA
    thurmanmerman;176724 wrote:
    Im sure a rotary not in boost could do so. Where is Zac when you need him. He would know.
    http://www.carsdirect.com/1993/mazda/rx7
    17/25
    ....Thats worse than an LS1 (19/28), only with 65 less hp, and about 120 ftlb's less TQ.
    Thats odd....
    :icon_scratch:
      That's a 13b-rew out of a 93...not an older Turbo II motor out of an FC...which had bigger injectors and stuff, and yes most of that was highway, but still it had much more power than stock. I still believe in keeping RX-7's rotaries, if u want 700+ hp just boost a 3 rotor. I like motor swaps, I have them in my cars as well, I just believe in keeping the same companies motor in that companies chassis...Honda motors in honda's and GM motors in GM products, etc...
      • 7ormore7 Offline
        7ormore7 Offline
        7ormore
        94NDTA;176719 wrote:
        Me too.
        I would like to see a 400 rotary get 26mpg in town as well.
        I'm assuming he meant highway.
        yeah that will prolly never happen at 400 maybe at 200 hp if you're lucky, thiers a reason are car shoot fireballs so easily 😄
        • 94NDTA9 Offline
          94NDTA9 Offline
          94NDTA
          And I am ok with that. I'm sure u didn't get your car because of it's gas mileage.
          • 7ormore7 Offline
            7ormore7 Offline
            7ormore
            yeah alot of people assume because its a 1.3 liter that it gets good gas milage, not saying you're one of them but its just kinda funny, i also get wow i bet all the gerbils are running in that thing, and "you know you just dumped oil in your gas", i roll my eyes and say yes, i run pre-mix like a snowmobile.
              my weed whacker uses mixed gas...cool.
              • ErikE Offline
                ErikE Offline
                Erik
                I absolutely hate this argument.
                They call me, old man...
                  I think running mixed gas would be a bitch. Therefore, I will keep my OMP. haha
                  • GrrG Offline
                    GrrG Offline
                    Grr
                    zac is hiding under a rock! actually hes been working like 14 hour days every day making $20+ an hour, so i dont blame him. But, I am not aaginst rotaries at all either, i love em in fact. But when it comes down to it they are WAY too fragile to make serious every day HP with. Like when im screwing with boost and shit, I can just lay into it until i hear some serious audiable knock, turn the boost down a little and im fine. On a rotor, ANY audible knock or detonation is some serious shit, and could be your ticket into a new motor at any time.
                    Also, when it comes down to it, the reason the rotor makes so much power is because its equivalent to a fuckin 6 cylinder 2- stroke. And yes it is a fuckin 2 stroke i dont care what anybody says. You mix gas, it uses ports instead of valves, and makes a complete combustion cycle in 1 revolution of the cylinder, that my friends is the definition of a 2-stroke. Also, its a 6 banger as it has 6 individual compression chambers.. Im sure every rotary fanboi is gonna try to prove otherwise, but tough shit, it is what it is.
                    AND, not baggin on zacs car or anything, shit i helped build the damn thing, BUT, If they are supposed to be sooooo badass, how come i can pull on him on a COMPLETELY STOCK motor with a turbo, in a car that weighs exactly 1000lbs more. now my engine in his car? holy fuck that would be fast. imagine ported heads and some bolt ons and it would do 9's on fuckin pump gas any time. I do like the $300 rebuilds he pulls out of his ass though, that would be sweet, and when we tore the motor/ trans out of it in what was it 2 hours at BI that one night, haha, that was fun.
                    BTW, anyone that wants a cheap swap, you can score a complete 5.3 out of a 1/2 ton silverado for about 7-800$, find a T-56 for $1500 shipped and its a damn good combo. you can buy heads, cam, headers the whole works to swap, and when you blow it, pick up a 6.0L shortblock for $500 or so and you got a 500whp motor no problem, should scale about 2700lbs withthat as well.
                    Gary
                    EDIT: BTW, wankels dont get good milage because every time we go anywhere we gotta keep the thing over 2500rpm or it will fall on its face, and 80mph is just over 3000rpm as well. I can idle around town and never even touch 2000rpm, 80mph, 2590rpm, and it will be about 2300 next year. PLUS, i scored 24mpg in mine on teh highway, and i held it to the floor a number of times on that trip.
                    2006 Trailblazer SS- my DD
                      Pre-mixing is better for the engine (rotaries). The oil-metering system on them doesn't lubricate the seals near as good as pre-mixing. I know many people that pulled the metering system out and pre-mixed 2 stroke oil in when filling up, if I remember right the oiling system uses 4 stroke oil...which is not made to lubricate when being burned. It's not much of a hassle, just put the right amount of oil in a bottle, dump it in and fill it up...maybe a minute longer to fill up.
                      • RE-EnemaR Offline
                        RE-EnemaR Offline
                        RE-Enema
                        This argument is stupid.
                        Both engines are great. The main thing is to keep an equal weight distribution front to rear on a very well engineered chassis. Mazda designed a great looking and one of the best handling sports cars of its time with the FD.
                        Neither engine is bad.
                        LS1 great power, lots of torque, weighs about the same as a 13b rew.
                        Turbo Rotary-quirky, smooth, spools turbos very well, can make good power
                        Now if I were to build my dream FD it would be a 3 rotor N/A. You can make approximately 400 hp. Reliable as hell. Weighs the approximately the same as a 13b rew.
                        400whp is more than enough for the FD on a large road course. 90% of the drivers on here could barely use the car to its full potential on a track with that sort of power and handling.
                        Now here is where I am going to catch some shit. The FD is NOT a drag car. Mazda never intended it to rip down the 1/4 mile. Why would they put all that time, money, and effort into the suspension and chassis? They designed it for handling. If you want a rotary drag car, buy a Starlet, backhalf it, and throw a rotary in it. That would be one hell of a scary ride.
                        • 94NDTA9 Offline
                          94NDTA9 Offline
                          94NDTA
                          Would you rather have a car with instant TQ/Power, or a high reving NA rotory for a track car (not drag)?
                            Considering Rx7.com had an N/A FB RX-7 that rans 9's in the 1/4...
                            • 94NDTA9 Offline
                              94NDTA9 Offline
                              94NDTA
                              .....Considering what?
                                17/25
                                Thats odd....
                                :icon_scratch:
                                hmm, 400hp Corvette getting at least 26 on the highway what??? :lol: I gotta hand it to chebby boys, they sure do make a good motor.
                                  U said NA rotaries cant make drag cars....
                                  • zbrownZ Offline
                                    zbrownZ Offline
                                    Yes I live, and so does the car still.... now on 20psi with alk. injection and still untuned:(....... that motor has seen far more than its fair share of abuse and it is still running, and i only popped one other motor that i built.... due to my idiocy, ask any that were there, on brittle OEM seals
                                    I dont know why everyone is getting out of hand, cant we all get along 🙂
                                    I like a SBC just as much as any of you yet i like the rotary too, guess i am weird
                                    Just cant beat the incredible simplicity of the rotary setup and the ease of working on them...1.5hr rebuilds at 300 dollars comon
                                    ... we'll see (if i ever get back there) for the rotary haters:)...lets say this car is not the same base 12 second car on 10psi and 2.0 60fts....... as it is now on 20psi let alone 30 tuned.... comon the gt42 wasn't even warmed up at 10lbs:)... oh yeah alk injection FTW and 89 pump.... thanks to Parker
                                    on 20psi the car feels like a solid 10 second car for sure
                                    and just something i wanted to throw out there... there are multiple 1000hp 13bs...... and a boosted 20b will get you your all desired even hp/Tq #s... usually around 500/500 on around 8-10psi
                                    there is a LS7 powered fd floating around that i saw....... that even gets me wet
                                    rx7-8.89@157mph
                                    12v dodge, twins
                                      I like a SBC just as much as any of you yet i like the rotary, guess i am weird
                                      there is is a LS7 powered fd floating around that i saw....... that even gets me wet
                                      when you coming back?
                                        not soon enough.
                                        • 94NDTA9 Offline
                                          94NDTA9 Offline
                                          94NDTA
                                          No I didn't. I said which would you rather have for the track (not drag strip)
                                          I never said they couldn't be drag cars/engines.
