  4. shifting=2g eclipse
shifting=2g eclipse
23 Posts 13 Posters 2.1k Views
  • GarageAlchemistG Offline
    GarageAlchemist
    roadracer;215966 wrote:
    There it is. Take it or leave it. Preferably leave it, and leave the site as well. Oh and please keep telling kids who want good advice that they can powershift/synchro shift their DSM's. Get em off the road faster...
    I probably will! i never said i told the kid topowershift, i said i do it! because i know how! we ant all be honda lovers!
    psi2hi, thank you for giving a better idea of what to look for. thats all i was looking for.[/QUOTE]
    actually the make sure the pedal was fully depressed was very DSM specific advice because when an aftermarket clutch is installed in a DSM, alot of the time you need a longer clutch slave cylinder rod, and if you dont have one, the car would act exactly like you said your friends car was.... So yea, we were trying to help...
    97 GTi, 03 KJ
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      91nbtsi
      roadracer;215965 wrote:
      there! now somebody said something! thats what i was looking for. not" make sure pedal fully depressed", "change fluids".
      I told you to make sure the clutch was disengaging fully; meaning the actual clutch, not the clutch pedal.
      PSI2HI gave you possible causes of the clutch not disengaging, same difference.
      Changing to a good fluid is important in these transmissions. GM synchromesh is a decent fluid that is commonly used to help the synchros out a bit.
      But, apparently I am just a know it all and wasn't trying to help you out.
      [email protected] -- DSM
      07 Mega Cab 5.9 CTD
      • treimcheT Offline
        treimcheT Offline
        treimche
        I've had more 2G DSM experience than I wish. 2Gs don't have issues w/ the clutch not fully disengaging like the 1Gs did. They all use cables from the shifter to the trans, which is gay and sloppy. Like Nate said, switch to GM syncromesh, or Penzoil syncromesh, which is the same stuff, but cheaper. This should all be done and can all be found on the DSM VFAQ site: B&M short shifter, metal shifter plate bushings, Greddy counterweight shift knob, SS braided clutch fluid line and get rid of the fluid collection unit w/ that, remove the clutch fluid restricter inside of the slave cylinder. Of course if your slave or master cylinder are leaking, replace them. Make sure that there isn't a floor mat or something getting underneath the clutch pedal. When all this is done, it still won't shift that good because its a Mitsubishi transmission. Compared to other cars, their trannies are garbage, this has been proven time and time again. Like I said before, spend the money with Shep or TRE, thats your best bet.
        Troy
        2009 Yamaha R1
        2002 WRX
        2001 Toyota Tundra
        2001 Yamaha R6
        1988 Yamaha YSR 50
        2003 XR50
