  4. New for 2009 Crx build thread!
88 Posts 23 Posters 7.5k Views
    Yesterday I started on the LS/VTEC motor build for next season. I had a very clean rebuilt LS sitting around for a while, so time to get to work.
    Took off the oil pan;
    Then the oil pickup and windage tray;
    Look how clean this motor is!
    Pistons out (New LS pistons for sale BTW)
    It has a fresh hone, and been hot tanked so that will save time and money.
    Next I want to get a new crank, I'm thinking GSR, ITR, or CTR instead of the LS crank. They are zero balanced to higher RPM's then LS cranks. also a ITR oil pump, the move more oil then LS pumps. I have not decided on what piston rod combo to go with yet either. I have a oil cooler for it too.
    The Ground Controls are set up and ready to go. My Koni yellows should be here any day now.
    Thats all for today!
    • DrifterExtremeD Offline
      DrifterExtreme
      all new b series pumps are the same.
      also ls crank will be just fine for anything you will do bryce.
        Is the key word "new" oil pump? In the past when I read about lsvtec builds they always would run ITR oil pumps because they pumped more oil.
        That is true on the crank, it will be boosted so I doubt I will rev past 8,ooo rpm.
        • inspector01I Offline
          inspector01
          What does being boosted have to do with only revving to 8k?? Boost means you can actually make power up there, might as well go to 8.7-9k depending on the head...
          PVC Squad Member #1
            DrifterExtreme
            bryce i think any pump newer then like 96 is the same as the itr pumps. the itr pump is just the revised version of the b series pump.
            but if your doubting yours pull it apart and check for wear if there is none you should be fine to run that one.
            Oh and trevor i think his power band will drop before 8500 so if it drops at say 8k there is no point to rev higher other then a gearing issue.
            but i'm preaching to the wrong person... haha
              Good to know, thanks Matt.
              What I have read is that Honda balances their crank shafts 1,ooo rpm past that motors rev line. That is why people put AP1 cranks that are balanced to 10,ooo in their K series. The rev limiter is 7k on a LS so I figured anything past 8k would be unsafe with that crank. It will be a stock B16 head, and IM.
              If I'm wrong, I'm wrong, but thats where I got my reasoning.
                what's on it for suspension at the moment?
                  inspector01
                  Yea, it will obviously depend on the turbo/cams/IM/etc, but assuming he stays stock B16 head and not too big of a turbo, it will drop off early enough.
                  PVC Squad Member #1
