  4. thrown timing belt on DSM
55 Posts 17 Posters 2.6k Views
    burnteclipse
    Questions for the same topic....i know there is a few set mile intervals where dsms should replace the timing belt does anyone know of what that is off hand?
      slowvo
      Damn, i gotta quit and join the aftermarket shops, thats where the money is at.
      ticklemedaly wrote:
      And for pay wise, I make more than most of them, only ones that make more are the ones with at least 20 years of experience and have been with that company the whole time.
        Shut up Garberg, your a baller.....
        • O Offline
          O Offline
          out there
          every 60k
          www.dsmtuners.com
          • ticklemedalyT Offline
            ticklemedaly
            now I, recommend at the most 60K....hondas, they recommend 90K, at the same time, I recommend at 60K at the most. with these type of engines and them being interference types, it is best to replace them earlier than the manufacture recommends, just for safety and security. Turbo charged dsm's, I recommend at the most 50K, while normal ones should be good to 60K.
            XBL G-tag: TickleMeDaly83
              ticklemedaly
              Jim wrote:
              Ok... unless I'm confused, the last time I checked: replacing valves in a head, machine work, whatever else <200. Used motor 1500-3000
              Yes, if the motor only needs a belt, and the valves replaced, it isn't that bad, but it isn't that cheap.
              The reason I would replace a motor on a dsm is mainly if the engine has suffered major damage from the belt braking AND it has a history of low oil pressure for a significant amount of time. In this case, replacing at least 4 valves, machining the head, labor to get to all of it, flushing the coolant and changing the oil, replacing the oil pump....which is the front case assembly on a dsm...replacing all the belts including the tensioner and highly recommended pulleys, all front seals, and the labor to do all the front engine stuff....well, you get the point, it adds up quickly and gets to be way too much. Now, with the oil pump having low pressure for too long prolongs engine wear, you more likely than not have damage to the rings, bearings, and every other friction surface in the motor.
              Now this is all the work that an experienced technician who has prior experience on a dsm would recommend, especially if the motor has high miles.
              Also, most used motors for a dsm go for 900-1500, maybe 1800 at the most for a turbo one. With even half the labor then replacing all the parts. And we can warranty a used motor longer than the repair work that would have been done. Now, which would you chose as the customer? The AVERAGE Joe Schmo out there who just wants the motor to run to get them to point A from B. Not us others who would do all the performance mods and would pay the extra cash to have it rebuilt to a higher performance motor.
                Good luck finding anything with less then 150,000 miles on it for $900.
                Used 4G63 motors DO go for 1500-3000.
                The average joe schmo who buys a turbo DSM (now days remember, they are cheaper, so a younger crowd can afford them), beats the piss out of thier car.
                • bluejaysB Offline
                  bluejaysB Offline
                  bluejays
                  just for some prospective from someone else who works on dsms. when I put a hole in one of my valves. kevin refused to just rebuild the head. he told me the only way he would fix it would be to either replace the motor or have the whole engine rebuilt, because my engine had lots of miles and was worn.
                    If your motor has other problems... besides just a few bent valves, then yes, it would be cheaper to buy a new one / rebuild the entire thing...
                    You don't want to spend the money fixing one problem, just to have more down the line...
                    • bluejaysB Offline
                      bluejaysB Offline
                      bluejays
                      and i think thats his whole point
                        ticklemedaly
                        I believe I just installed 2 recently to know what they go for....A BRAND NEW REMAN goes for 3K, and that is just a long block.
                          ok! I hope those $900 engines last a long time!
                            ticklemedaly
                            considering they are gauranteed to have between 40 and 60K on them. They should, otherwise a bad rep follows.
                            • treimcheT Offline
                              treimcheT Offline
                              treimche
                              So where do these $900 turbo 4G63 motors come from?
                              Troy
                              2009 Yamaha R1
                              2002 WRX
                              2001 Toyota Tundra
                              2001 Yamaha R6
                              1988 Yamaha YSR 50
                              2003 XR50
                                ticklemedaly
                                Did I say a turbo one was that cheap? The basic 4G63's go that cheap, while a turbo one goes upwards of 1800 for a damn good one with low miles. If you are pay any more for one, you are screwing yourself out of your money. These motors are EVERYWHERE.
                                Many junk yards....but then again, I have a good hook up through work.
