  3. Events
  4. Auto-Cross on the 25th at the Dome
34 Posts 22 Posters 2.3k Views
    no RB for me...its got its issues right now but we are working on them before i leave...
      ill be there watching. my brakes are beyond shot, id rather spend the 500-600 for the brakes i want after i get motor swap done and running again.
        thezachattack240
        I'll be there. This will be my first auto-x and I can't wait to run with my blown struts. Gonna have body roll like mad probably. Hopefully I can get my ruca's in before saturday. Does anyone know if they have loaner helmets or anything? It should be fun though even though I have a feeling I'll get rocked, but its all good. And just for shits and giggles here's a break down of some of the classes:
        G Stock (GS)
        -any shocks/struts
        -any front sway bar
        -any reasonably quiet exhaust, from catalytic converter back
        -comfort and convenience: light bulbs, stereo system, etc.
        -any street or R-tire that will fit on stock sized and stock offset wheels
        -any brake pads
        -stainless steel brake lines on cars older than 1992
        -remove spare tire/jack
        -bolt-in roll bar or cage
        -harnesses
        Street Touring-Street Tire (STS)
        -all GS allowances
        -any springs
        -coilovers
        -polyurethance bushings.
        -any rear sway bar
        -strut tower bars-front, rear, top, and bottom
        -header
        -intake
        -pulleys
        -front camber bolts or camber plates
        -rear offset bushings or adjustable rear upper control arms
        -any wheel up to 7.5”, any offset, with any street tire (treadwear > 140) up 225 width
        -any stock sized slotted/drilled rotors
        -removed/disabled air conditioner
        -any shifter/short-shifter
        -any steering wheel that does not disable/remove a stock air bag
        -any fully padded/upholstered front seats not less than 15lbs. Each
        -body kits
        -brake ducts
        Street Touring-Street Tire Extreme (STX)
        -all STS allowances
        -any differential
        -any bolt-on brake upgrade that retains e-brake
        -hi-flow catalytic converter
        -any tire (treadwear > 140) up to 245
        -any wheel, any offset up to 8”
        D Street Prepared (DSP)
        -all GS allowances
        -all STS allowances except adjustable rear upper control arms and body kits
        -any front valance
        -any rear spoiler that doesn’t extend more than 10” from bodywork, no wider than the car
        -any wheel, any size, any offset
        -any tire, any size, and treadwear
        -removed/disabled emissions system(s)
        -non-stock electric fans
        -any organic clutch
        -any differential
        -removed heat and dust shields
        -any steering wheel
        -weld-in roll bar or cage
        -update/backdate from other trim levels of the 240SX (VLSD, HICAS, etc.)
        -any fully padded/upholstered front seats capable of accommodating an adult
        -ported heads-no material can be removed more than one inch from port openings
        -fender flares
        Street Mod (SM)
        -all DSP and STS allowances
        -any Nissan/Infiniti engine (including SR and RB swaps)
        -unlimited engine/drivetrain mods (turbo KA’s, bore, stroke, carbon fiber driveshafts, port and polished heads, high/low compression pistons, etc., etc., etc.)
        -unlimited suspension using the same pickup points (adjustable control arms, ball joints, etc.)
        -removed back seats
        -fender flares
        -replacement front fenders of any material
        -replacement hood of any material
        -hood scoops/vents
        -any brakes that retain e-brake
        -any spoiler that does not extend more than 6” off to the side of the car on either side and or more than 10” high
        -2400lb minimum weight
        E Modified (EM)
        -1500lb minimum weight
        -any engine over 2000cc
        D Modified (DM)
        -1000lb minimum weight
        -any engine under 2000cc
        That's just a rough summary if anybody cares. And I got this off a 240 forum hence all the nissan talk throughout it. I'm sure the same rules apply to other cars though. See everyone out there.
        My cardomain site
        • M Offline
          M Offline
          mym6
          I will be there and running so long as I can get into a loaner helmet. I'll also have a digital camcorder and digital camera so if anyone wants in car video or pictures taken at certain corners let me know. I'll of course be in a red mazda6 wagon.
          • Sweet-WRX-LovinS Offline
            Sweet-WRX-Lovin
            You gotta have a helmet? If so that knocks me out for sure.
            One time...
            • M Offline
              M Offline
              mym6
              I asked the question and it was answered as so --> http://fargostreet.com/showpost.php?p=1864&postcount=7
              • FlowcusF Offline
                FlowcusF Offline
                Flowcus
                Well I have a couple of helmets so I can bring a spare for anyone if I run... need new tires first.
                I ride random bitches.
                • M Offline
                  M Offline
                  musthavemuzk
                  i have to come and watch now. i was not sure what to expect and well i am still not real sure, but it sure seems like a blast to watch.
                  so count me and my digital camera there as well.
                  Monty
                  14.59 at 94.85 still stock
                  www.pbase.com/musthavemuzk
                  • 9 Offline
                    9 Offline
                    92TSIpos
                    damn it. I buy $1000 coilovers and my car blows up. WTF. Well if there are any DSMs that wanna compete with bad ass suspension hit me up.............please 😄
                    • J Offline
                      J Offline
                      JDMSTi
                      wish i could be there but im gunna be in Texas for a week, and I still have my winter tires on the RS...I need new tires and then i'll run in SM i beleive this year
                      • wa2fastcamaroW Offline
                        wa2fastcamaro
                        I was going to run, but sounds like too mant people are going to be there. I liked it when there were no more than 20 of us running. But with talks of record numbers, I'm out. Gunna watch though, and play with my RC cars.
                        Boys and Their Toys Auto
                        Phone: 701-371-5615
                        E-mail: [email protected]
                        • FlowcusF Offline
                          FlowcusF Offline
                          Flowcus
                          Im sure its going to be a nice long event... And 20-30 people isnt really that many! Ever been to an Auto-x in the cities? I watched one and there must have been over 100 cars with 2 courses... it was retarted.
                          • M Offline
                            M Offline
                            musthavemuzk
                            should be good with 2 or 50 cars. then again this will be my first and well i enjoy car related functions. so i am good to go. now get here already....geez
                            Monty
                              Gonna be there to watch but not race. Too tired to even think of racing right now.
