  4. New Turbo...
New Turbo...
29 Posts 22 Posters 2.1k Views
  • PSiedTSiP
    PSiedTSiP
    if he dumps it wont bust creep and what not...no kaboom
    spanish-rice;237125 wrote:
    • O
      O
      out there
      boost creep is still possible, that's why he would need a very large wastegate to run a lower psi, but running +/-30psi wouldn't require a very large one.
      i don't know what some of you guys are babbling about with it taking forever to spool, it does have full spool (to low 20s) by 3800-4000
      • 91nbtsi9
        91nbtsi9
        91nbtsi
        I don't think people should comment on big turbos when they haven't had anything bigger than a 14b;) I ran a 38mm gate on my car and it was fine down to 15 psi, never tried anything lower than that. I am pretty sure my turbo was bigger than this one, or close in size. It was at 35psi most of the time though:) Will be interesting to see this turbo run, that is if Jim ever gets his car going!
        [email protected] -- DSM
        07 Mega Cab 5.9 CTD
        • P
          P
          Spool up rpm claims are a waste of time. They are never accurate and vary so drastically from setup to setup. If your worried about spool up keep the 14b.
          • DaveHD
            DaveHD
            DaveH
            Spoolup is over rated.
            DaveH
            '94 Supra- 7.77 @ 176mph
            • EfiniE
              EfiniE
              Efini
              everyone knows everything.
              92TSIpos
                If there are people with 14b's faster than those with large turbo's then why even upgrade at all?
                • JimJ
                  JimJ
                  What he's saying is that, if you care about spooling up quickly, don't buy a big turbo. The stuff that makes you go fast, top end power, is what big turbos are good for.
                  14b's are quick, but not fast without EVERYTHING else being top notch. A big turbo + the same top notch = always faster...
                  • O
                    O
                    out there
                    my comment about 3800-4000 is what the majority of people on other boards with 2L (dsm and wrx) are claiming. also interesting, is that 2.1-2.4 guys aren't spinning it up much faster, i think the lowest i've read is about 22psi by 3500ish.
