  4. Racer or Ricer
Racer or Ricer
31 Posts 23 Posters 4.2k Views
    TonyTSi
    -30% racer x
      correct me if I'm wrong but I dont think question 20 has the correct answer.
      1. Again, correct order. IC=intercooler, CC=combustion chamber, TC=turbocharger, UP=up-pipe, DP=down-pipe
        Filter, IC, TC, CC, UP, TC, DP, exhaust
        Filter, TC, CC, IC, DP, UP, exhaust
        Filter, TC, UP, IC, CC, DP, TC, exhaust
        Filter, TC, IC, CC, UP, TC, DP, exhaust
      Shouldn't it be...
      filter, TC, UP, IC, CC, TC, DP, exhaust?
      • My NOvaM Offline
        My NOvaM Offline
        My NOva
        Gran Turismorator
        You scored -17%
        You are a respectable tuner. You probably subscribe to one or more tuner magazines and know, quite a bit about your car and/or racing in general. Either that or you play a shitload of GT3. At any rate, you recognize the difference between a wastegate and a blow-off valve. In time, and with practice, you may attain "Racer X" status since it is supposed that you are relatively new to tuning and still have much to learn. Keep, working, and thank the maker that you're not a ricer.
        not bad for a muscle tuner
        Hey Tina come get some hamm
        • ErikE Offline
          ErikE Offline
          Erik
          pin wrote:
          Question 19 doesn't have a correct answer.
          The correct answer is Intake, Compression, Power, Exhaust. 😮
          -24 %
          "Keep, working, and thank the maker that you're not a ricer." Keep studying English and correct the grammar mistakes.
          No, there is a correct answer, you have to think of it in terms of a cycle. You can really "start" anywhere in the sequence. Its the follow order that matters.
          They call me, old man...
            pin
            If you think of it logically, the engine can't start without the intake cycle being first. Nobody teaches the 4 cycle engine design any other way because it's the basis of everything.
            Barry
              probe this
              -22% Not bad I guess.
              My probe is fast. How fast? Line up next to me at the track and find out.
              I can pull my probe faster than most ricers can race. haha
              99 black lightning 496whp, 620ft/lbs heavy pig
                SVT Guy
                -22% after you took it 3 times lol
                  probe this
                  -19% with my car (fwd sport compact),-22 with both rwd viper, and awd evo, sti
                    SVT Guy
                    more tuner than i was -6%....just as long as im not ricer i guess.....
                    • LT1L Offline
                      LT1L Offline
                      LT1
                      0%
                        Purple_94GT
                        Shouldn't it be...
                        Up-pipe as they are referring to is is the same as the manifold on a 4 cylinder or the sum of the two banks on a v type motor (V6 or V8, not VTEC).
                        Correct order = Filter, TC, IC, CC, UP, TC, DP, exhaust
                        Intake air through the filter on the cold side of the turbocharger where it is pushed through the compressor. Then it enters the intercooler to be cooled before entering the combustion chamber. It is then burned and expelled through the manifold into the up-pipe (collector) and goes through the hot side of the turbo which drives the compressor. Gases then go through the downpipe, which is connected to the exhaust or in many cases on modified turbo cars the atmosphere.
                        BTW - 22%
                        Lucas
                        1994 Ford Probe GT - torn apart for mods, longest FI project ever
                        2003 Chevy TrailBlazer - PCMforless.com tune, 20" Boss 315s, Aeroforce scan gauge
