  4. Machine Shop to work on H-series...
24 Posts 12 Posters 2.0k Views
  • XJHEADX Offline
    XJHEADX Offline
    XJHEAD
    Equipment Requirements
    Something else to keep in mind about diamond is that it works best in power honing equipment that has been designed to take maximum advantage of diamond’s honing properties. There are a number of companies that make diamond honing heads for use with various honing machines: Rottler, K-Line, Kwik-Way, Peterson, Winona Van Norman, Sunnen and others. But because of the increased loads, diamond may overtax some older power honing machines and increase the risk of stripped gears. It may be better to buy a new honing machine that has more horsepower and rigidity to handle diamonds.
    "Most of our customers who hone with diamonds use a CK21 machine," says Sunnen’s Mera.
    As for portable honing equipment, conventional abrasives are the better choice for this type of application. Most of those we spoke with say diamonds require too much pressure for portable honing equipment.
    Another difference with diamond is the type of lubricant that’s required. A synthetic water-based lubricant is usually recommended instead of honing oil.
    K-Line’s van den Bergh says, "water-based lubricants are easier and cheaper to dispose of than oil-based lubricants because they can be evaporated down to reduce their bulk. On the other hand, they occasionally require make-up water and have to be monitored to prevent bacterial growth.
    "The type of lubricant you choose is very important because it can make quite a difference in honing performance. With conventional abrasives, you want a good quality honing oil. A lot of people run into honing problems because they’ve diluted their honing oil or tried to use something else like diesel oil or kerosene," says van den Bergh.
    Anthony Usher of Rottler Mfg. in Kent, WA, says the OEMs all use long-lasting superabrasives with metal bonded honing stones. But the equipment and controls they use are very expensive, which makes it difficult to bring the same technology into a typical aftermarket job shop.
    "About 12 years ago, we decided to change that. If new engines are originally honed with diamonds, why can’t we develop the same technology? So we set about developing honing equipment, controls and stones that would put the same technology into the hands of a job shop," says Usher.
    "Diamonds last a long, long time. Because the stones don’t wear away, you can control the size of the bore more accurately," Usher explains. "This allowed us to build an automatic control system that allows us to size bores exactly the same every time."
    Usher says for under $30,000, a job shop can buy a diamond honing machine that substantially reduces running costs and gives better results.
    "The HP6A power stroking automatic honing machine is our newest product. It runs with diamond abrasives and has a programmable load control for both rough honing and finish honing. When it is finishing the cylinder, it automatically reduces the load because some cylinders have very thin areas that may distort if the load isn’t changed. The HP6A has a base price of $23,900 and a fully equipped unit goes for $28,000 to $35,000."
    Plateau Finish Is Best
    Regardless of what type of honing equipment or abrasives are used to finish cylinder bores, more and more shops are finding a plateau finish provides the ultimate finish.
    A plateau finish is one that closely resembles a broken-in cylinder bore. When the bore is honed, the surface of the metal will have microscopic peaks and valleys. Peaks don’t provide much ring support, so as soon as the engine is started the piston rings start to scrub up and down and shear off the tallest peaks. As the engine continues to run, the peaks will be gradually shaved down until the cylinder bores are relatively smooth and flat (except for the valleys in the crosshatch that must be there to hold oil).
    The normal engine break-in procedure will eventually produce a plateau finish anyway. But until it does, the rings and cylinders will experience unnecessary wear and the engine will experience increased blowby, oil consumption and emissions until the rings have seated – which might take several hundred or even several thousand miles to complete.
    A better approach is to precondition the bore surface so the rings don’t have to "hone" the cylinders. A plateau finish will provide maximum compression right from the start, and eliminate most ring seating and sealing problems.
    One recipe for achieving a plateau finish is to bore or hone to within .003˝ of final size. Then finish to final dimensions with a #220 or #280 grit conventional abrasive and follow up with half a dozen strokes of a #600 grit stone, cork, or a flexible brush or nylon bristle plateau honing tool.
    If diamond stones are used, bore or rough hone to within .005˝ of final size. Then hone the cylinder to final dimensions with #325 to #500 grit diamonds, followed by six to eight strokes with a flexible brush or plateau honing tool. Many experts recommend leaving a little extra metal in the bore for final finishing if diamonds have been used to rough hone the cylinder. This is because rough honing with diamond leaves a very rough finish (over 100 RA depending on the grit of stone used).
    Honing Hard Materials
    In recent years, Nikasil coatings have provided a challenge for engine builders. Nikasil is a hard coating of nickel and silicon carbide about .0025˝ to .003˝ thick that is applied to cylinder bores to improve wear resistance. Invented by the German firm Mahle, Nikasil was originally developed for the Mercedes Wankel rotary engine. It has been used by BMW and Porsche in some of their engines, and is also used in many chain saw engines, some motorcycle and marine engines, and even many NASCAR Winston Cup engines.
    Goodson’s Jensen says PERs have had success honing Nikasil treated cylinders with diamond. But for smaller shops that have only portable honing equipment, you can’t exert enough pressure with diamond to hone Nikasil. The best advice here is to use #220 silicone carbine and just do a couple of strokes to deglaze the cylinder. If a cylinder has to be bored to oversize, cut it out with a boring bar and then hone in the usual manner to achieve the desired dimensions and finish.
    Ed Kiebler of Winona Van Norman in Wichita, KS, says new harder coatings on cylinder walls are forcing shops to change to diamond honing and to upgrade their equipment.
    "I see a lot of shops who are interested in diamond but who don’t fully realize what’s involved in the diamond honing process. Diamond takes a lot of pressure to cut. Some people use diamond on portable hones, but realistically you can’t get enough pressure to make the diamonds perform well. Having said that, I truly believe the new harder cylinder coating materials are going to force people to go to diamonds," says Kiebler.
    "The two-cycle stuff is all Nikasil. Now the outboard engines are going to Nikasil, too. All the NASCAR Winston Cup shops are using Nikasil cylinders. If it’s good for NASCAR, it’s not going to be long before you start seeing it in OEM engines," Kiebler explains. "The time is coming when you’re going to have to use diamonds if you’re going to hone Nikasil cylinders."
    Kiebler says all most shops do is slightly roughen Nikasil cylinders. "You don’t really remove much material. The Winston Cup shops are running some of these motors five races before they redo the cylinders. The Nikasil coating really extends ring life and cuts down on ring wear."
    OEM TRENDS
    Dave Riley of Gehring L.P. in Farmington Hills, MI, a supplier of honing equipment to original equipment manufacturers, says almost all OEM internal combustion gasoline engines in North America today are being rough honed with diamond abrasives.
    Riley says the OEM focus is on using water soluble synthetic honing coolants, which means diamond abrasives because vitrified conventional abrasives require honing oil. The other industry trend he sees is that cylinder bores are being respecified to smoother finishes.
    "We’re talking 0.15 to 0.3 Ra finishes that are extremely smooth," says Riley. "They’re doing this to further reduce emissions. A lot of this is being driven by ring technology because rings can now survive in conditions that provide much less oil. However, in my opinion these new surface finish specifications are reaching the limits of technology."
    One of the things that the OEMs do to achieve high quality bore finishes is to use computer numerically controlled (CNC) honing machines. The cutting speeds of these machines are 50 to 75 percent faster than what was used 10 years ago. Faster cutting speeds allows the abrasives to cut smoother, and finer abrasives can be used for a smoother finish without sacrificing cycle time.
    7.64 @ 187 3400 lbs. on KORN
    TTSBF
    RTCTTFMF PTOSITW
    • XJHEADX Offline
      XJHEADX Offline
      XJHEAD
      Riley says the laser structuring process is ideal for hard blocks or those with special surface coatings that make them difficult to finish with conventional honing techniques. "It’s a perfect application for high performance, diesel and aircraft engines," he says.
      Remember To Clean The Bores
      As we wrap up this article on honing abrasives, one final point to remember is the importance of cleaning the bores after honing. Honing leaves a lot of metallic and abrasive debris in the bores – which must be removed before the engine is assembled. Washing and scrubbing with warm soapy water will remove most of the loose debris. Some engine builders follow up by wiping out the cylinders with automatic transmission fluid. The point is get the cylinders clean so there are no contaminants to damage the rings or to get into the oil.
      <<Side Bar>>
      WHY DIAMONDS ARE SO EXPENSIVE
      If you’ve balked at the high cost of diamond honing stones, here’s a brief explanation why they’re so expensive:
      Diamond is a special form of carbon that is formed naturally under extreme heat and pressure deep inside the earth. As such, it isn’t very plentiful or easy to find. Subsequently, man-made synthetic diamonds are mostly used for industrial abrasives.
      Scientists realized that if they could duplicate the heat and pressure that formed natural diamonds deep in the earth, they could transform ordinary graphite (another form of carbon) into diamond. They estimated it would require temperatures in excess of 6,300 degrees F and pressures of approximately one million pounds per square inch to make the transformation occur. But as the scientists discovered, it wasn’t so easy. Try as they might, they couldn’t get graphite to change its crystal structure and become diamond – until General Electric researchers discovered the secret in 1951.
      A catalyst was needed to make the change happen. The catalyst turned out to be a mixture of molten iron, nickel and cobalt. The various proportions of ingredients in the catalyst are still a closely guarded secret, so only a couple of companies in the entire world have the expertise to produce synthetic diamonds. In the U.S., synthetic diamonds are produced at GE’s plant in Worthington, Ohio. Several years ago, we were given a plant tour – but nobody except a trusted few are allowed to see inside the room where the diamonds are actually made.
      GE says they can create different types and sizes of synthetic diamond for various industrial purposes by varying the temperature, pressure and type of catalyst. Man-made diamonds typically have a yellowish tinge and are as small as grains of sand. Even so, they’re ideally suited for their intended use as an abrasive. They’re just as hard as natural diamonds and actually perform better because of their custom-tailored shapes and characteristics.
      TTSBF
      RTCTTFMF PTOSITW
      • ErikE Offline
        ErikE Offline
        Erik
        I was 13 years old when I started reading that....
        They call me, old man...
          and Ur done with the first post net year!
