  4. rotary mechanics
rotary mechanics
20 Posts 12 Posters 1.3k Views
    id suggest lundes or i have heard that caleb at type-r does rotary work
      no, as far as I know, caleb does not do rotary builds/rebuilds. I know he has a couple 7's sitting around that he is planning on getting running but he will be buying a motor for them iirc.
      • 7ormore7 Offline
        7ormore7 Offline
        7ormore
        I'm in the proccess of starting the rebuild my T2 but the rebuild kits are so damn expencise and i know i'm gonna need new housings.
        • Spec_RS Offline
          Spec_RS Offline
          Spec_R
          so i guess if u don't know much about those engines, then Fargo isn't a great place to own a RX-7? how about modifying the car?
          • EfiniE Offline
            EfiniE Offline
            Efini
            Marty at Lunde is one of the two rotary mechs in the state. The other is in GF. Marty did my engine install, 30k on that motor now with not one problem, with the motor that is. You dont need to be a rotary guru to own one. Most 7 owners will have there motors built to the needs they want i.e. street port, race port, 3mm seals ect. Working on a rotary has the same principals as a piston motor; air, fuel, spark. So working on them and modifying them is almost the same, if you know how to install a piston motor you know how to install a rotary. Unless you plan on ripping into the motor and changing the dome of the rotor, you'd be fine with owning one.
            Eric you are the exception...
            • itRfanI Offline
              itRfanI Offline
              itRfan
              Well i guess that about sums it up then...hahaha^^^^^
              -weshole
              • usmcjsyU Offline
                usmcjsyU Offline
                usmcjsy
                Well depending on what kind of build you want I know of a couple of guys that do them outta their homes. I had mine rebuilt by a guy out in PA and he did a street port other than that it was just new seals and springs. Si far so good, there is also another guy I think the website is www.rotaryresurrection.com Other than that I think you can get a Mazda Reman for like $1800. As far as modding goes the rotary is one of the easiest engines to work on. There is plenty of room under the hood to work with. I have done some decent upgrades to mine and it took real well to every mod. So dont be scared because the # of rotary specialists/gurus is low in this area. With the I-net these days help is never really to far away. Plus there is a ton of rotary shops nationwide that can build you a motor.
                • RaiderR Offline
                  RaiderR Offline
                  Raider
                  Marty does know his rotary's but he is no longer here at Lunde's
                  POWERD BY
                  • EfiniE Offline
                    EfiniE Offline
                    Efini
                    WHAT? Where did he go, retire? He was kinda old. Here at Lunde's? Ur there right now? lol
                      • RaiderR Offline
                        RaiderR Offline
                        Raider
                        He was let go a few months ago
                        POWERD BY
                        • EfiniE Offline
                          EfiniE Offline
                          Efini
                          What! Let go...how in the fuff do you let go your only certified rotary tech let alone one of two in the state! Not very smart on Lunde's part if ya ask me.
                          • RaiderR Offline
                            RaiderR Offline
                            Raider
                            I agree with you
                            POWERD BY
                              that is a quite stupid idea that be like firing the computer tech at bestbuy
                                HAHA, like a tech at best buy is worth a shit anyway!!
                                • Spec_RS Offline
                                  Spec_RS Offline
                                  Spec_R
                                  let go as in he want to go or he got fired?
                                  really? he was one of the best rotary mechanic in the state...?
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    Marty was a good tech for the older mazda's but he couldnt produce the hours that Service wanted...he was/is very good at what he does but he just takes his sweet time at doing it and wasnt making the shop money so they let him go...Im sure if you guys need work done he would do it on the side at his house...he loves the rotary and I think he has a few motors laying around at his place as paper weights
                                    POWERD BY
