  4. cheap performance
cheap performance
22 Posts 13 Posters 2.4k Views
    3.8s respond way better to a turbo....bunch of people make a ton of power with a turbo L36
    • AcesHighA Offline
      AcesHighA Offline
      AcesHigh
      I didn't think you can put a Mitsu 20G into a Camaro. In fact, I doubt it, a 4g63 manifold would not fit. Anyhow, "cheap performance" really doesn't exist. You really won't get much power spending money on an aftermarket intake or header. Lots of money equates to lots of power.
      Nitrous would probably be the best bang for the buck here.
        just because you use a mitsu turbo it doesnt mean you have to use the 4g63 manifold lol...drake is using a 16g and chuck is using an 18g...think about it
          Mine is tiny 🙂 - just a wee bit larger then the stock td05...but you know I think it spools just about the same - but I have the boost loop set REALLLY low.
          • AcesHighA Offline
            AcesHighA Offline
            AcesHigh
            How would the turbo bolt on? You can't exactly put a Mitsu turbo onto, say, a Garrett manifold.
              different flanges
              • J Offline
                J Offline
                JDMSTi
                I thought you had the stock turbo?...btw the stock WRX turbo is the TD-04 😉
                • My NOvaM Offline
                  My NOvaM Offline
                  My NOva
                  Race him and find out if its stiock I for one know its not stck and its been upgraded to a larger one w stock ic and its f@##IN fast 😮
                  Hey Tina come get some hamm
                  • dubbsyD Offline
                    dubbsyD Offline
                    treimche wrote:
                    Sell it.
                    agreed.
                    BUT....
                    5speed or auto?
                    5speed - aftermarket shifter of your choice to cleanly sling through the gears.
                    Auto - Torque Convertor possibly. Would have to know the specs on the factory unit, but a new TC could probably wake the car up.
                    Gears - good ole standby
                    -straight pipes/headers. It's a V6...who knows how good that will actually sound.
                    I'd wait before either of those and find someone who has experience with that motor...find out if either of those would pick up any horsepower. I'd bet the heads/intake don't flow enough to warrant some huge exahust setup (and then you fight with losing the torque numbers)
                    for not-so-cheap performance, look into what's available for Heads (probalby an OEM port/polish job) and a cam. I'd be willing to bet Vortech has a kit for that car...if not (for some cars) they're not too hard to piece together....and go that route.
                    (I'd reccomend looking into a F-body forum for input honestly...)
                    • M Offline
                      M Offline
                      mym6
                      Is this the same 3.8 that is found in the Pontiac GP? If so you could steal some ideas from them. I know there is a more aggressive rocker arm set you can get for that engine, would be a good project.
                      edit: Not lifters, rocker arms.
                        the turbo would be very easy and inexpensive for some quick power. 20g (or so) would flow enough for about 350-400hp. with a large turbine you could control the boost more easily, and keep it from spooling constantly. personally... i would just get some headwork, cams, and good intake and exhaust
                        • NickBN Offline
                          NickBN Offline
                          NickB
                          burkhardt is turning into a ricer
                          • 2wheeler2 Offline
                            2wheeler2 Offline
                            2wheeler
                            Please don't do straight pipes. You will actually lose HP/TQ. Do a good exhaust like Flowmaster and an air intake. Put a small hit of nitrous on it and you will be very happy. If it's an auto, do a converter.
                            I know there was a supercharged 3.8 around here at one point. Was actually pretty cool.
                            '08 Suzuki Hayabusa
                            '09 Yamaha Zuma 200cc
                            '95 E-350 7.5L
                            • dubbsyD Offline
                              dubbsyD Offline
                              http://mods.firebirdv6.com/
                              read through all of that....
                                adog
                                For some more detailed info, try ls1.com. They have a section for the unfortunate V-6 F-body owners. A guy got 13's N/A out of his, at least on the internet. Here's a site that might help you out: http://www.firebirdv6.com/ . You can be almost as fast as the LS-1's. 😄
                                • My NOvaM Offline
                                  My NOvaM Offline
                                  My NOva
                                  got me from 255 to 295 for 700$ 😄
                                  • NickBN Offline
                                    NickBN Offline
                                    NickB
                                    His is a stick
