  3. Wanted Ads
  4. needed soon Crx turbo manifold!
29 Posts 10 Posters 1.8k Views
  • B
    B
    bemidji123
    i need perferribly a log manifold for a Crx it is for a ZC16 i need one externally wastegated prolly a 38mm flange and i need it for a t3/t4 turbo had one but it cracked or is there anyplace to get one custom made??? had one but it cracked
    • DelSlowD
      DelSlowD
      HF manifoild?
      • JimJ
        JimJ
        He needs it externally gated man... and the hack job to an HF would be super ghetto
        • DelSlowD
          DelSlowD
          didn't see the external wastegate, sorry.
          HF adapter plates aren't ghetto..if you get the right one they are pretty clean...
          • JimJ
            JimJ
            Homemade-turbo shit = ghetto
            • DelSlowD
              DelSlowD
              ummm ok...
              • DrifterExtremeD
                DrifterExtremeD
                you have a pm
                • integra_gsr98I
                  integra_gsr98I
                  http://www.straightlinespecialties.com/
                  His manifolds work.
                  My GSR
                  11.2 @ 130 high trap of 134
                  Joe's Evo
                  11.7 @ 120
                  Nick's Hatch
                  11.9 @ 114
                  Kevin's Hatch
                  12.2 @ 113
                  Jeremy's DSM
                  11.8 @ 124 IIRC w/ junk trans
                  • JoelJ
                    JoelJ
                    I would say go for Nicks manifolds at SLS. But the external wastegate to HF manifold can look clean if done right.
                    legacy image Looks way better than all of the external hackjobs on 4G63t mani's i've seen.
                    • DelSlowD
                      DelSlowD
                      ^^^Amen.....
                      • integra_gsr98I
                        integra_gsr98I
                        That looks like shit. How you even can consider that looking "clean" is beyond me. Why halfass shit and use garbage?
                        Do it right or don't do it at all.
                        • K
                          K
                          that is the truth
                          • DrifterExtremeD
                            DrifterExtremeD
                            Well i hate to say it but some ppl don't have $300 to spend on a log manifold. or in your case $800+ on a top mount witch is more then some ppl make in a month when there still in school....not saying that it isn't nice to have the best stuff just don't say do it right or don't do it at all. why is it only perfectly tig welded ss manifolds are alowed on cars. when did DIY become the wrong way, idk about you but i would rather see a car built buy the owner then some kid with money that knows nothing but has a SWEET setup that is done right....just pisses me off when ppl thik that there is only one way to do things
                            • DelSlowD
                              DelSlowD
                              matt speakin the truth. Exactly what was on my mind. +10 e-penis points for matt.:icon_cheers:
                              • P
                                P
                                It wont last. Exhaust manifolds are typically made of cast iron which does not hold a strong weld and will crack over time.
                                • P
                                  P
                                  Because typically when you do a junkyard style setup parts fail, or parts fall apart and in the long run by the time you end up fixing them and or replacing them time and time again you have almost just as much if not more i nvested into a pile of worthless parts then you would had you just bought something nice from the get go. As the saying goes "buy it nice, or buy it twice." It doesn't matter if he buys a manifold from me or from someone else, im giving my input from what i know and what i've seen in the past. I can list @ least 3 or 4 local people who did junkyard style setups and not 1 of them worked out well and a few of them blew up.
                                  • integra_gsr98I
                                    integra_gsr98I
                                    My OLD setup was a mig welded mild steel non merge collected manifold. It worked OK I guess, but was still a piece of shit and cracked, fell apart, etc.
                                    In this industry you 100% hands down get what you pay for. If you build it yourself, and you use cheap materials, it will fall apart. If you purchase it and it is cheap and THEY use cheap materials, it will fall apart. Building a quality manifold costs more than most think when you calculate in a QUALITY welder, gas, filler, time, materials, flange planing, etc everything adds up.
                                    $300 or so for a manifold with a LIFETIME warranty for the original owner, built with high quality materials and welded w/ high quality equipment is pretty cheap if you ask me.
                                    It's the same as when it comes down to tuning hardware. There is a reason the FAST CARS use EXPENSIVE engine management and not Crome or Uberdata or something else that is either cheap or free. You ALWAYS get what you pay for.
                                    EDIT
                                    Also, I'd rather see a HAPPY CUSTOMER with a setup that WORKS for a long time than a customer with a piece of shit setup that works for a bit but doesn't last.
                                    • 91nbtsi9
                                      91nbtsi9
                                      I give that wastegate runner about a week before it cracks at the manifold..if that. Just look at it, it is a pos. Buy an eBay manifold if you don't care if it falls apart:) Atleast it will look good to start!
                                      • DrifterExtremeD
                                        DrifterExtremeD
                                        Well see not everyone makes as much money as you do not saying your rich but you have a good job that pays. your not 17-19 just out of school and want to boost your d15/d16 for some extra power. What your not understanding is that ppl can and HAVE had good setups that were cheaply put together. Also i don't know what your deal is with crome/crome pro, and uberdata but there is no reason to spend $1200 on aem ems when you can get neptune for $600 tuned or free programs. What is really wrong with a FREE tuning program? ppl make tons of power on these programs and have used them racing and on the street.also price doesn't mean shit look at one fab he fucked everyone and charged a shit ton, his manifolds also cracked. so does this mean his shit is the best because it cost $1000? fuck no
                                        • JimJ
                                          JimJ
                                          Mine worked for maybe two months 🙂 And the turbo fell off on the way to kevins lake 🙂
                                          ... but it was shiny
