  4. cam gear adjustment?
43 Posts 11 Posters 3.0k Views
  • inittowinitI
    inittowinitI
    inittowinit
    well a friend of mine put a v tec head on his 92 civic and now his rings are shot. could the head be the problem?
    • DelSlowD
      DelSlowD
      I have that done on my car, d15b7 block with a d16z6 head. Just take your time and dont cut any corners and your good. If you just replace the key parts (new seals, gaskets, ect.) you will be A-OK:icon_thumright: Nice little boost of power.
      • wesholeW
        wesholeW
        wannabe wrote:
        mini me! u put a vtec head on the d15 and vollah, 30 hp.
        Put a bottle on it and VOILA! 60+ hp.
        • inittowinitI
          inittowinitI
          inittowinit
          cool. i have a chance 2 get a v tec head from a 2000 civic 1.6. i have been told it will fit but am not sure?
          • DelSlowD
            DelSlowD
            what year is your car? if you know the engine code that would be better.
            • inittowinitI
              inittowinitI
              inittowinit
              its a 92 lx.
              • JoelJ
                JoelJ
                then u should be rocking a d15b7. mini me will work fine with that head! buy it up.
                • inittowinitI
                  inittowinitI
                  inittowinit
                  sweet! much apreciated!! for under a hundered bucks i figured i cant go wrong. still need new distributer and wire though
                  • DelSlowD
                    DelSlowD
                    if i were you i would look around and try to pick up a d16y8 head. They flow better. Plus that and if your looking at a 2000 head that is OBD2, and you are OBD1. y8's are OBD1. but...its your car
                    Mini me's FTW:icon_cheers:
                    • inittowinitI
                      inittowinitI
                      inittowinit
                      the head is a d16y8
                      • DelSlowD
                        DelSlowD
                        then buy that meng. Gonna need to convert your dizzy to OBD1 still.
                        • inittowinitI
                          inittowinitI
                          inittowinit
                          that no big deal though! thanks again!
                          • DelSlowD
                            DelSlowD
                            Yeah, where you from. Might be able to help ya
                            • inittowinitI
                              inittowinitI
                              inittowinit
                              fargo!!! The help would be much apreciated. My roomate is a gear head but the more the marryer
                              • DelSlowD
                                DelSlowD
                                yeah whenever you do that just tell me and im sure some of us will come help a fellow Honda drive.
                                • inittowinitI
                                  inittowinitI
                                  inittowinit
                                  nice! dont worry you will be hearing from me quite a bit. Im not much of a mecannic but am interested in tuning, and i need to start some were!
                                  • DelSlowD
                                    DelSlowD
                                    Yeah everyones gotta start somewhere. What are your plans for it?
                                    • JoelJ
                                      JoelJ
                                      lol@ will. z6=obd1 noob!
                                      • inittowinitI
                                        inittowinitI
                                        inittowinit
                                        well with the 1.5 i got im not to sure? Would like to do a all moter but a swap would be the only way i would satisfie me. If i work with the 1.5 a turbo ,ight be on the menu
                                        • DelSlowD
                                          DelSlowD
                                          durka dur joel...
                                          You should boost it. Know a guy thats got all the stuff you would need probly, minus the turbo.
