  4. FS: MTX Amp
FS: MTX Amp
8 Posts 3 Posters 728 Views
  • W Offline
    W Offline
    wo1fpack2004
    For Sale: 425 watt mtx 2 channel amp..sold my subs so i dont need the amp...first $100 takes it
    here are the specs..
    THUNDER8302
    RMS Power measured at 12.5 Volts DC:
    75 Watts x 2 into a 4 Ohm load with less than 0.1% Thd+N
    150 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
    300 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
    Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
    120 Watts x 2 into a 4 Ohm load
    212 Watts x 2 into a 2 Ohm load
    425 Watts bridged into a 4 Ohm load
    Signal to Noise Ratio: ≥110dB A-Weighted
    Damping Factor: >200
    Frequency Response: 20Hz-20kHz ± 0.25dB
    Maximum Input: 8Vrms
    Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
    Crossover: Variable 40Hz to 200Hz, 12dB/octave high pass,
    24dB/octave low pass with mono output
    Dimensions: 9.2" x 9.75" x 2" (22.8cm x 22.8cm x 5.1cm)
    11.5" x 9.75" x 2.1" (29.2cm x 24.8cm x 5.3cm) Including IsoFeet™
    • W Offline
      W Offline
      wo1fpack2004
      trades considered
      • W Offline
        W Offline
        wo1fpack2004
        bummmmp....
        • 9 Offline
          9 Offline
          95TsiAWD
          What are you looking for on trade. I will be up to minot on tuesday or weds.
          95 TSi AWD
          Old Turbo #'s
          522whp/414wtq
          [email protected]
          11.3@129mph
          Procharged 99 Corvette
          95 LS6 Mustang
          01 300m
          06 Suzuki LTR-450
          • W Offline
            W Offline
            wo1fpack2004
            what do u have to trade?
            • W Offline
              W Offline
              wo1fpack2004
              free 12" sub box with purchase of amp
                u wanna trade for the psp yet?
                • W Offline
                  W Offline
                  wo1fpack2004
                  amp is sold...mods can close thread
