  3. ICE and Detailing
  4. Engine hum through speakers
22 Posts 9 Posters 2.8k Views
    slowvo
    if i use an alternate source and hook it to the RCA's i get no noises at all. its defenitly coming from the HU.
    also, the engine is COP.
    i think im gonna power up the HU with a external battery and see if it goes away, if it does i guess ill rewire the power and ground coming into it
      Are you running the alternate source down the same RCA cables as the deck is running on or are you just hooking up the new RCA's at the amp and unhooking the RCAs that the deck uses?
      If you aren't using the same RCA's then it could be in the cables, if you are using the same RCA's it is almost definately in the deck.
        slowvo
        Yup, i hooked it up to the rca's that would normally go to the deck...
          then it is probably the deck, try locating a new ground for it and/or ground the chassis of the deck to the same grounding spot that you are grounding the ground wire to.
            Just a thought here, it's possible that your amp is bad too. We actually just had a car come in at work and narrowed the problem down to a bad amplifier.
            • Hocus Focus 2001H Offline
              Hocus Focus 2001
              QFT
              I've found that those RCA cables with the ground wire in them is good for equalizing a ground loop.
              2002 Supercharged Ford Focus SVT
              #3617 of 4788 - its nice to know your place in the crowd!
                Except that the noise goes away when he removes the deck and uses an alternate source to feed the amp.
                • 91nbtsi9 Offline
                  91nbtsi9 Offline
                  I gave him some advice..which should work if the supply to his deck really is the issue. He did find info on the net to back up my claims as well, heh. Putting a cap between the power and ground should get rid of any AC signals present. It does this by blocking any DC and allowing AC to go to ground. I guess maybe I did learn something in those stupid circuits classes? 🙂
                    what happens if the faulty ground is coming from the antennae though nate? You still need to ground the chassis of the deck to the same spot as the ground of wire coming off the harness if that is the case. It could also be a poor ground internally on the deck from the circuit board to deck chassis. But yes, a cap will do as you stated if he does in fact have a dirty voltage supply coming to the deck.
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      That was the only problem I was trying to cure for him.
                        hehe, I figured as much, but its in my nature to complicate things beyond necessity.
                            slowvo
                            Well, i changed the ground entirely, grounded the case, put in a capacitor between the pos and neg....hooked it up, and now the noise is only coming through the center and right speaker...
                            i remember with my old setup it was coming through the right speaker only.
                            you were right, time for a new car!
                              hmmm....that is odd to say the least, try swapping in someone elses deck and see if that works maybe??
                              • 91nbtsi9 Offline
                                91nbtsi9 Offline
                                Sell it.
