Ford GT
Jim wrote:
I wouldn't park it in the lot... damn i'd be so scared!For sure, any new car your always paranoid about the smallest door dings and so forth.. Some people sometimes don't have respect or aren't careful.
But obviously, wannabe; you saw the same car as I did, unless the there are two that look exactly alike rolling around.
i see you spotted my beater
That car is always at the theater.Or when i go it is.
Raider wrote:
nice car...there are a couple of guys doing motor swaps in there trucks with the GT motor...they should be 10's trucks with that setupAre you saying that if you put the GT motor in a truck it'd run 10s?? Just wondering...
A853 wrote:
Are you saying that if you put the GT motor in a truck it'd run 10s?? Just wondering...with there current setups and amount of boost they will run on the GT engines...they should be in the 10's
a Lightning can easly be in the 11's with pulley swap and bolt ons....the fastest L on stock block is in the high 10's
Raider wrote:
with there current setups and amount of boost they will run on the GT engines...they should be in the 10'sa Lightning can easly be in the 11's with pulley swap and bolt ons....the fastest L on stock block is in the high 10's
Okay; you lost me, because if you were to take the Engine out of the Ford GT and put it in the truck per say like a Ford Lightning, you think it would run 10s? What boggles my mind is the ideas of this, a stock Ford GT runs about equivilant with a Dodge Viper roughly; so roughly the Ford GT is only a 12 second car.. Since the Viper and GT are pretty good match ups and now your talking about putting that engine in a truck which is obviously heavier, it should runs 10s? Or are you talking about if the engine out of the Ford GT was modified after it was installed in the truck...??
id say dont fuck with Raider when it comes to ford's. you will be throughly owned.
I was talking about keeping the engine stock; like a direct swap; I knew it wasn't possible
I wasn't saying the swap was impossible, just taking 1 motor of a lighter car, putting into a heavier truck and running tens w/o any mods..
