  4. Battery problem
Battery problem
23 Posts 12 Posters 1.5k Views
    If its an optima there is a 99.9% chance its bad.....their quality has gone down the shitter lately.
      just take your car over to advanced auto. they do free battery checks. Go to the one on 13th and 25th and go when A.J. is working, he'll hooks you up.
        it takes like 3 days to charge.
          Really? Anyone have a charger they could let me use?
            well i dont know about 3 days...takes more like 10 hours....and you have to use the slow charger....
              JN607 wrote:
              You should be able to hook up a voltmeter to it... switch it to amps and put the positive lead to the positive and the negative to the negative, if you don't get a reading, then you know it's dead...either that or bring it to a parts store. Normally, they will just switch them out for no charge. At least, not here anyway...
              Thats great if you want to destroy your meter by shorting out the terminals through the meter.
                If you're lucky you'll just blow the meter fuse...
                  yeah, but some meters like my cheapy are not fused. 😞
                    Optimas do have a warranty, you can probably get it warrantied, even if it is used. Well that's assuming the battery is actually bad.
                      slowvo
                      How would it do that?
                      he almost had it right....i think what he meant is to put a voltmeter set on amps in series of the - battery cable...which wont blow any fuse or meter unless you have a the key on or a very excessive load (over 10A).
                      ive done this many times and its a great test.
                        u have to trickle charge it, I have one that I could let you borrow. Or maybe we could just charge your battery here since the charger is actually not mine
                          again, I'm willing to bet the battery is shot. My yellowtop was good for 2.5 months before it took a crap on me...I cannot get optima to warranty it either.
                            Sweet Joel! I'll give you a call when I get off work tonight.
                              Chuck, he never let the battery charge? cant really tell if its shot if it hasnt even been charged.
                                sounds good BTW, why did u buy a truck/offroading battery for your accord?
                                  I sold the rims and teins and bought a lift kit and swampers.
                                  • F Offline
                                    F Offline
                                    fanaticrockford
                                    I have had the same yellow top for the last 5 years. It's probably sat on a shelf not in use for 2 years though.
                                      5 years ago they still made good batteries, it was in the last 2 or so years that their quality went to SHIT. Anyone from Tintmasters/Ground Assault wanna back me up here?
                                        If it didn't have enough charge after 15mins+ off driving to even start the car, the battery is fucked. I'm not saying it should be fully charged by then, just that it should have sufficient charge to start the vehicle or at least turn it over a couple of times. Optima recommends charging them ON THE ALTERNATOR for 35 minutes to get a full charge and significantly longer if on a trickle charger.
                                          I love my optima and have never had a problem with it.
