  4. Battery problem
Battery problem
23 Posts 12 Posters 1.5k Views
    If you're lucky you'll just blow the meter fuse...
      yeah, but some meters like my cheapy are not fused. 😞
        Optimas do have a warranty, you can probably get it warrantied, even if it is used. Well that's assuming the battery is actually bad.
          slowvo
          MisterCMK wrote:
          Thats great if you want to destroy your meter by shorting out the terminals through the meter.
          How would it do that?
          he almost had it right....i think what he meant is to put a voltmeter set on amps in series of the - battery cable...which wont blow any fuse or meter unless you have a the key on or a very excessive load (over 10A).
          ive done this many times and its a great test.
            u have to trickle charge it, I have one that I could let you borrow. Or maybe we could just charge your battery here since the charger is actually not mine
              again, I'm willing to bet the battery is shot. My yellowtop was good for 2.5 months before it took a crap on me...I cannot get optima to warranty it either.
                Sweet Joel! I'll give you a call when I get off work tonight.
                  Chuck, he never let the battery charge? cant really tell if its shot if it hasnt even been charged.
                    sounds good BTW, why did u buy a truck/offroading battery for your accord?
                      I sold the rims and teins and bought a lift kit and swampers.
                      • F Offline
                        F Offline
                        fanaticrockford
                        I have had the same yellow top for the last 5 years. It's probably sat on a shelf not in use for 2 years though.
                          5 years ago they still made good batteries, it was in the last 2 or so years that their quality went to SHIT. Anyone from Tintmasters/Ground Assault wanna back me up here?
                            If it didn't have enough charge after 15mins+ off driving to even start the car, the battery is fucked. I'm not saying it should be fully charged by then, just that it should have sufficient charge to start the vehicle or at least turn it over a couple of times. Optima recommends charging them ON THE ALTERNATOR for 35 minutes to get a full charge and significantly longer if on a trickle charger.
                              I love my optima and have never had a problem with it.
                                FWIW, the battery won't hold a charge at all. Joel trickle charged it for me and it still didn't hold enough juice to start my car.
