94 civic.... look!
i got a 95 civic coupe, no rust, 17s, new struts/coilovers, 4-2-1 stainless header, test pipe, apexi N1 cat back, CF whale penis intake, new ignition stock.
Before there's any true interest, you should answer the questions everybody has been asking you...and on another note...you fix this problem?
yeah someone brought that link up in mnsportcompacts... it was leaking out of one of the vaccum lines/pcv plumbing... totally fixed....
for 5 ill take off the turbo kit, leave everything else on there
this is whats included for 5
built ls/vtec
2000 civic b16 head on a 93 integra block
je pistons 9:1 .020 over
skunk 2 TB
Eagle H Beams rods
Fidanza lightened flywheel
gsr cams
apex-i 2.5" cat-back exhaust
Golden Eagle vaccum manifold
Hasport urethane motor mounts
s80 tranny (00 b16 tranny)Body
Shaved door handles with compustar remote and alarm
body kit side skirts molded on- urethane
buddy club 2 front bumper- fiberglass
rear bumper- not sure what kind- urethane
VIS carbon Fiber hood and trunk
tinted windows
angel eye one-peice headlights
m3 mirrorsinterior
GSR full leather re-wrapped to color match exterior
cobalt gauges
sony 7" in dash motorized touchscreen dvd playerRims/Suspension
17" excel silver rims
tenzo-r springs
new axles
new lower ball joints
ls rear disc conversion
4 wheel slotted/cross drilled rotorsand no, i understand about the link... but i mean i fixed it, all it was was, the first time i had the map sensor externally mounted because i didnt see there was a port on the skunk2 TB for it, so boost was leaking out of there, then i had the pcv plumbing venting down, so boost was leaking out of there too... but now everything is fine... ill post up pics/numbers of my compression tests tomorrow..... also, i still have the spec sheet from when i built the motor.. bore size, bearing clearances, etc...
Willling to sell any of the parts separately?
thought you were gonna trade me for my eclipse
how much for just the motor and no turbo kit? im interested in the motor but have no use for the body. i have 93 EX turbo that needs engine work. 5 thousand for no turbo kit? what if you took off all that other crap like the body kit and wheels and all that other stuff i dont want. ?
97slowgsx wrote:
thought you were gonna trade me for my eclipsei thought you said you were going to think about it and let me know?
SPANISH-RICE wrote:
how much for just the motor and no turbo kit? im interested in the motor but have no use for the body. i have 93 EX turbo that needs engine work. 5 thousand for no turbo kit? what if you took off all that other crap like the body kit and wheels and all that other stuff i dont want. ?i dunno, id really have to think about it, id almost have to sell the car with the body kit because the side skirts are molded on, id have to think about a price... pm me with everything you wouldnt want
i said i'd like to test drive the car and everything else, you told me you'd let me know when u were comming to fargo sometime....pm me if ur still interested.
