  4. Weights and weight bench.
8 Posts 4 Posters 680 Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    I'm upgrading to an Olympic set.
    Weider 138 bench
    Standard bar (30lbs)
    Standard EZ curl bar
    2 Standard dumbbell handles
    All weights standard
    2 50 lb weights
    2 25 lb weights
    4 10 lb weights
    4 5 lb weights
    4 2.5 lb weights
    2 1 1/4 lb weights
    $150 obo.
      possible to take some pictures?
        of the bench
        • 94NDTA9 Offline
          94NDTA9 Offline
          It has the side peices and the leg peices, but I never put them on.
            I had one like that and the position of the pedastals were right where a normal bench grip would be located...is this one like that?
              You will get huge using this bench!
              • 94NDTA9 Offline
                94NDTA9 Offline
                Somewhat. If you have a really wide grip when benching, it wouldn't be for you, but if you keep your lifts normal, it works just fine.
                • 94NDTA9 Offline
                  94NDTA9 Offline
                  Bump, still for sale, will take offers...
