Interstate Dragways Rules question
moparguy wrote:
You will need a helmet and the top up. Faster than 13.99 and the driver does need a harness. The track is a NHRA track and if anything were to happen to someone that was allowed to go down the track illegal to nhra rules, then the track would lose its NHRA status. so it is enforced quite a bit.
If you havent run before you will also need long pants and at minimum a tshirt, preferably a long sleeve shirt, or we will turn you around and send you out until you change.Hope this helps you out alittle bit.
Thanks for the clarification!
I should be all set now. -
The battery do need to have a hold down, and no, a bungee cord does not work. I tried that one myself once. it didnt work. If the vehicle has a trunk mounted battery, I beleive it needs to be in a mounted battery box, and im not sure exactly on this one but i beleive it needs to have a firewall between the battery and the driver. I dont know all the rules, I just announce there.
It really depends on the weather and if we can get enough heat in the track early on. But I'll see what we can do for ya. Its the best I can offer for ya. Im thinking if we start right at 12 around 1 or so there would be enough heat in the track to give er a rip.
moparguy wrote:
The battery do need to have a hold down, and no, a bungee cord does not work. I tried that one myself once. it didnt work. If the vehicle has a trunk mounted battery, I beleive it needs to be in a mounted battery box, and im not sure exactly on this one but i beleive it needs to have a firewall between the battery and the driver. I dont know all the rules, I just announce there.I've helped people pass tech because I had a roll of Duct tape to tape down the battery on a street legal day. The tech gave him the idea.
