  4. cable internet question
47 Posts 10 Posters 3.8k Views
    Switch = Multiport Bridge
    Router = Advanced Switch
    • JoelJ
      JoelJ
      Angel is trying to say that if you take 24 mbps into a 4 port hub, the max of each port is only 6 mps, regardless of whats running off the other slots. a router will only deliver is to what is using the connection... Either way I don't think thats Mike's problem. No idea what it is to tell you the truth. Just use a different wireless connection, like a neighbors, if you can.
      • PSiedTSiP
        PSiedTSiP
        That is not true either Joel.
        spanish-rice;237125 wrote:
        • Turbo5OhT
          Turbo5OhT
          Turbo5Oh
          my rents live in the boondocks, house next to us has like 60 yr old people in it no other wirelss signals out here
          where can i get a 50 ft cable?
            for a hub, it is true.
            • wesholeW
              wesholeW
              I got an idea. Magically break the Xbox, steal it, or just steal the power chord.
              • PSiedTSiP
                PSiedTSiP
                No, it is not.
                  Quoted from Webopedia:
                  "When a packet arrives at one port, it is copied to the other ports so that all segments of the LAN can see all packets."
                  AKA what i was describing
                  • PSiedTSiP
                    PSiedTSiP
                    Yeah, how does that equal the connection being divided?
                    Ok, enough whoring this thread. Either you need to learn how to explain what you are saying or you really need to go back to school. 🙂
                    • MisterCMKM
                      MisterCMKM
                      Nope. You were not describing that at all.
                      thrash;315544 wrote:
                      Ford is back :)
                      • PSiedTSiP
                        PSiedTSiP
                        Thank you Chris.
                          lol. i know what im talking about, must just be coming out in a fashion that you guys arent understanding.
                          oh well.
                          BACK ON TOPIC. NO MORE BS BELOW THE LINE.
                          • S
                            S
                            stirno
                            You need to implement some QoS (Quality-of-Service) rules using your router. Most modern routers have this functionality accessible via their Administration interface. Specifically the very very common Linksys WRT54G allows QoS rules based on device. Using this you can place your own machine on high priority and the Xbox on low. Will do what you want.
                            1998 Audi A4 1.8T // T-28 // Koni Coilovers // European Spec Headlights (Ecodes) w/HIDs
                            2007 VW GTI 2.0T // APR
                              Ok...each port has the POTENTIAL of seeing the full bandwidth coming in. However, as soon a port 1 is using say 1.5 Mb on a 3Mb connection all that is remaining for available bandwidth on any of the remaining ports is 1.5Mb. In this case, if the xbox is sucking up 2.9Mb all that remains for the other ports is .1Mb
                              As for the Cat5 cord, I can hook you up with that shell....I've probably got a couple laying around my house right now that you can have for little or nothing
                              • 91nbtsi9
                                91nbtsi9
                                Correct.
                                • T
                                  T
                                  thrash
                                  Without getting into too many details, it sounds plausible that plugging the PC directly into the router with a cable may help things. This is primarily because wireless is a broadcast medium by nature with a shared collision domain. An XBOX live game like halo2 or counterstrike can be thought of a constant stream of udp traffic - it is always sending data at a constant rate (technically xbox live traffic is inside of an IPSec tunnel so its not like you'll necessarily see udp packets flying by).
                                  In any case, if two radios try and transmit at the same time there is likely to be a collision and one of htem "loses" and has to try again. IN an environment where an xbox is sending data constantly, a PC that sends intermittently is likely to "lose". Also note that the traffic coming back the other way (i.e. downstream) is now split between downloading web content to the PC and downloading game data packets to the xbox, although those two shouldn't collide with each other as the sending radio (the router) will serialize the data.. however it still may collide with the upstream xbox packets.. i honestly dont know enough about collision resolution and back-off on 802.11 networks.
                                  Regarding A/B/G - A is the clear performance winner. As said elsewhere, G and B shared bandwidth and technology; the presence of a B radio greatly reduces the perfrmance of a G radio. Also, B/G share frequencies with many common cordless phones and even your microwave oven. A radios operate on a relatively unused frequency so are generally faster.
                                  Finally, regarding hubs, switches, and routers...
                                  The "collision domain" problem i describe above for wireless (the basic problem is, only one person can talk on the wire at once (per channel, i beleive.. so i was perhaps simplifying things a bit)) also applies to wired connetions. A hub is little more than an electrical mux where all the PCs are connected to each other. If 1 PC tries to transmit down the wire at the same time another PC does, there will be a collision and a backoff/retransmit.
                                  the more transmitting devices on the hub, the more likely collisions will be and the lower observed performance you will see.
                                  A switch makes this better by dynamically sizing the collision domains to the minimal set of involved machines. If you have 4 machines plugged into a switch, and Machine A is sending data to Machine B, and Machine C is sending data to machine D, and A-D are on different switch ports, all of this can happen without collisions. The reason for this is that the switch in this case acts like 2 hubs - A and B are connected together in one collision domain, and C and D are connected together, but AB traffic cannot affect CD traffic. The switch knows how to dynamically create mini-hubs because it keeps track of which MAC (the 48bit hardware address of each ethernet device) addresses are associated with each switch port. When traffic comes in it has a destination MAC address, and the switch knows exactly where to send that "packet". The switch operates at OSI Layer 2, closer to the actual electrical level.
                                  So, think of a switch as a device that creates one or more "virtual hubs" (not to be confused with VLANs, which are another switch feature) between just the computers that are trying to talk with each other at that instant in time for each mutually exclusive computer-to-computer transmission.
                                  A router is a layer 3 device, meaning it operates at the packet level and not so much the electrical/physical medium level. Packets are routed based on their ip address and knowing that a particular interface is the appropriate "next hop" for a particular address. Any device with two or more network interfaces is usually a router - the $50 "router" you buy at home has a WAN interface (cable or DSL), a LAN interface (whatever the included switch/router is) and sometimes a wireless interface (a "2nd" LAN interface), and moves traffic between all 3 at the IP layer, not the hardware layer.
                                  (there is such a thing as an L2 switch, actually, but not in a $50 home product)
                                  In any case -- plug the PC into the router with a long wire and see if it helps 🙂
                                    Yep.
                                    Limit that god damn xbox to only have a certain amount of BW.
                                    • S
                                      S
                                      stirno
                                      ... lol .. holy complex answers for a simple problem. 😜
                                      You don't even need to set specific amounts of bandwidth usage for anything, as long as priorities are set correctly the router will limit the xboxs bandwidth as soon as something with higher priority is making a request. 😉
                                      • PSiedTSiP
                                        PSiedTSiP
                                        Wow, I'm not really sure if that explanation was really needed. Either way, I would try plugging in as well. You usually get higher priority right off the bat. I was going to suggest the QoS someone else suggested until we got into the little discussion :).
                                          ❤ lol.
