  3. Track Talk
  4. Looking for a pontiac 455
57 Posts 14 Posters 9.5k Views
  • MisterCMKM
    MisterCMKM
    Anybody in here who reccomends a chebby motor be put in that PONTIAC Trans Am should be slapped.
    The 455 is a beast. It makes a helluva lot of torque and lots of power but you don't need to spin it up much. A 400 punched out and stroked to 462 is also a helluva combo. Bottom line is stick with the pontiac motor in that car. Its a lot easier than dicking around with putting a chevy in there (motor mounts, accessories, fitting under the shaker scoop and various other things).
    thrash;315544 wrote:
    Ford is back :)
    • capitljC
      capitljC
      capitlj
      I agree with cmk i just had to comment on the big block cheaper than a small block bullshit, what was that guy thinking? Anywho the power of the big block compels you. The power of the big block compels you.
      Mitch Hedberg wrote:
      2004 Impala LS 3.8
      • 94NDTA9
        94NDTA9
        That really depends on what deals you can get.
        $400 for a 455 and a 400 is a damn good deal.
        • wesholeW
          wesholeW
          bubba wrote:
          I know a kid from back home with a built 455 olds in a old jacked up chevy. I havent heard him having any problems with it and he drives it everyday, it seems pretty reliable. Only thing that ever broke was one of his axles.
          That's an Olds 455 in place of a 5.7 deisel slapnuts.
          • A
            A
            adog
            Pretty much that an LSX engine with wiring harness, PCM, and sufficient tweaking to produce 450-500 hp would cost more than a big block crate engine, at least if you got new parts. Also, the LS1 and LS2 were installed in the Formula/Trans Am and GTO, respectively, so putting them in a Pontiac would seem reasonable.
            • MisterCMKM
              MisterCMKM
              The LSx does not bolt right up to a 2nd gen Firebird. Also, they were only in the 4th gen 1998-2002 models. The LSx was never installed into a 2nd gen bird.
              The Pontiac motor will be the cheapest route in that car.
              BTW, there is no "big block" or "small block" with the pontiac motors. They are all the same physical size.
              Ford is back :)
              • K
                K
                they were not ever produced in that car. but there is probably swap kits. they make ls1 swap kits for 240sx's. and a LS1 has awsome potential and can get awsome gas milage for the power it can produce
                • A
                  A
                  adog
                  I knew it wasn't a direct bolt-in. I was just saying that it wouldn't be totally blasphemous to install an LS1. But, like I mentioned, it wouldn't be cheap.
                  • MisterCMKM
                    MisterCMKM
                    It would be in a classic Firebird like that.
                    Ford is back :)
                    • capitljC
                      capitljC
                      capitlj
                      I dont think you could spend another 5 grand on bolt ons and only get 400-500 hp on an ls crate motor. The general rule of thumb for those of us in the know is that big block parts will be double the cost almost all the time.
                      2004 Impala LS 3.8
                      • A
                        A
                        adog
                        I had based my estimate on the following:
                        LS1 crate engine + H/C: approx $7,000 + electronics, low 400 hp range
                        502 cid crate engine: approx $5,800 + carburetor, ignition, 450 hp
                        If the existing 400 is in good shape or an economical 455 can be obtained, that would be the most affordable route.
                        • MisterCMKM
                          MisterCMKM
                          The 400 or the 455 is the only logical choice. For one its a pontiac motor. Second, its a pain in the ass to find mounts to fit a chebby in the pontiac.
                          Ford is back :)
                          • capitljC
                            capitljC
                            capitlj
                            I was saying all along that the 455 is the better way to go just building one to make 500 hp is gonna cost roughly twice as much as putting in a 350 that makes the same power. Screw an LS motor why put all that electronic crap in a classic car like that?? Sure you can't get the same kind of turn key operation fuel injection gives you but the install is three times as complicated, plus you have sensors to maintain/replace and diagnosing a problem can be a PITA with fuel injection.
                            2004 Impala LS 3.8
                            • MisterCMKM
                              MisterCMKM
                              Not true. Have you ever owned a carbuerated vehicle?
                              Ford is back :)
                              • LightEmUpL
                                LightEmUpL
                                LightEmUp
                                Man....... you guys are getting into stuff I didn't want to know, I will be putting a <u>pontiac</u> 400 or 455 whether I bore it out or not which I probably will. I have some hookups through my dad, he knows some people in the auto business, but anyways im not that worried about price all I asked does anyone have a 455 you guys took it out of the park around the block and then some, o well also does anyone have a winter beater car for me so i can actually rip the 400 out of the car so I can get it rebuilt if no has a 455 well you guys have fun with that LS shit
                                1975 Trans am 455 8.99 @158mph (What now fallguy)
                                1987 CRSEX W/Fucking VVVVVVVVV-TEC (But is now sitting in a junk yard cuz I blew it up......Ooops!!)
                                2001 cr125 (Faster Than LoveMachines Bike)
                                • capitljC
                                  capitljC
                                  capitlj
                                  No i havent thats just what i hear from people who do as far as cold starts go. The only reason i said anything at all on this thread was because someone said a big block would be cheaper than a small block thats just plain madness.
                                  2004 Impala LS 3.8
                                  • 94NDTA9
                                    94NDTA9
                                    Putting in a crate LS1 is going to be a hell of a lot easier to get running right than a carbed 400 or 455.
                                    But I would rather get as 455 too. Don't even bother with a 400.
                                    • LightEmUpL
                                      LightEmUpL
                                      LightEmUp
                                      Yeah I really want to go with the 455 but it is so hard to find a pontiac 455 that is an early 70's those are the ones with the most horsepower If I end up going with the 400 it wont be so bad because i will be able to put better parts on it with the money I will be saving from not buying the 455 and I think a 455 has more expensive parts, but most parts are able to go on either what ever I do it will be sweet and it will definately be mean as hell
                                      • MisterCMKM
                                        MisterCMKM
                                        You can get a 455 block out of any pontiac. Throw an aftermarket set of heads on there, bore it and stroke it and you're easily over 500hp.
                                        Ford is back :)
                                        • 94NDTA9
                                          94NDTA9
                                          QFT.
                                          The only reason the older ones have more power is because of the exhaust, carb and cam. If you plan on swapping that out anyways, might as well pick up any 455 you can.
