  4. Update on my old Spyder:
24 Posts 13 Posters 1.7k Views
    http://www.mnsportcompacts.net/forum/showthread.php?p=524659#post524659
      At least you don't have to fix it this time.
        that car has just had bad luck hasnt it
        • M Offline
          M Offline
          MrScary
          I saw that and I wasn't for sure if it was yours or not!! Thats dumb luck there
            I dont know about bad luck; they must have been running it lean or else boosting like 30+ psi boost on pump gas...
            That motor shoudln't have blown up...
              Well, considering the wastegate vacuum line wasn't attached probably allowed them to run A TON of boost on a highway pull. Shit sucks, and I'm not too sure how MAP is going to build their car...haha.
                They are putting a 4G64 in it... and i guess they are porting the head too?
                  4g64 is a 2.4 single cam motor out of a syder GS FYI. Tons or torque for a 4 cyl, but I think traction will still be a HUGE issue in making that thing run 11's since he's keeping it front wheel. That thing will need some sweet ass suspension.and a nice traction bar, along with massive slicks. but, that would be one hell of a highway puller!
                    Joel, who are you telling that to? I think all of us that have posted know what it is.
                      most people dont know, just throwing out some general information.
                        Except that its a 7 Bolt and if you make any real power, it will crank walk...
                          He said its a 6 bolt version. They made a few of those as well.
                            what did the 6 bolt 4g64s come in? i never heard of them
                              ok harry.
                              • camzaro28C Offline
                                camzaro28C Offline
                                camzaro28
                                read one of the last comments on that thread. it said something along the lines of " fastest fwd stock turbo is in the 10's" ?
                                is that possible? just asking.
                                but IIRC dont the stock turbos max out somewhere around 400? and then FWD to pull it into the tens, dont seem logical.
                                like i said, just asking.
                                jig 4 prez
                                  Uhm the 4g64 6bolt came in Hyundais.
                                    and in the old mitsu trucks.
                                      the mighty max y0...and the way you tell if they have a 6 bolt 4g64 in them is if their MAS looks like one off of a 2g
                                        6 bolt 4g64 also came in older galants. That motor is still a POS and not worth the time/effort. Glad to see you don't have to deal w/ fixing that shit Jim!
                                          I had an 89 galant, it had a single cam 4g63 in it if I remember correctly.
