  4. launching
launching
31 Posts 14 Posters 1.4k Views
    capitlj wrote:
    It's different for every car and setup just pay for a track day sometime and try different techniques until you find the sweet spot. Oh and integra gsr whats your 60 foot time you dont have that in your sig. I'm sure all your speed comes in at the far end on the track right, not that your slow off the line but i bet you could be a lot faster if you could launch without roasting the tires.
    1.766 was his 60' and a .002 reaction as well. The 1.7 can be improved on, no doubt, but its still not awful
      When I ran a FWD car on small slicks, I launched almost exactly how I launched my DSM. Slip the clutch until you feel the car moving, and then dump the clutch from there. If you have a weak clutch, it will just burn, but if you have a good clutch, it should take off nicely.
      • theobliviousT Offline
        theoblivious
        alright cool guys thanks for all the help!
        BOOST....to be continued
          capitlj wrote:
          still quite a bit slower than a RWD with the same power and tires.
          So you are telling me that a mustang or slomaro with 400ish whp can run low 11's (using kevin's hatch as an example)...
          ok
          and as far as launching goes...rev limiter...drop 😉
          actually, I launch at around 4-5k...just depends on how much i wanna spin the tires (my sweet ass steelies y0)
            ok
            not sticking up for capitalj...but yes..if a mustang weighed the same as a civic did and it had 400hp...it would run low 11s
              my point is that a mustang with 400whp cant due to it's weight...my point was just that a civic with 400whp is faster than a mustang with 400hp...if you go power to weight ration and make them the same, then that's another story
                This is such a stupid argument. Weight is no the only factor. Traction, gearing, driver and suspension setup all play into it. There are mustangs with 400hp running low 11s.
                  bc you've never said anything stupid...EVER...:p
                    Nevar!
                    The whole argument is stupid though. Like I said, there are a ton of factors plaing into it that are not even mentioned.
                    • capitljC Offline
                      capitljC Offline
                      capitlj
                      Indeed.
                      > Mitch Hedberg wrote:
                      2004 Impala LS 3.8
                        Nick proved you an run 11's with 260hp in a civic. Lets see a mustang run a 13 with 260hp
                          im sure its possible. with right gearing, and setup ect.
                          • capitljC Offline
                            capitljC Offline
                            capitlj
                            Without a doubt. There are fox cougars and t-birds running 12s with only 325 hp and they are heavier than the stangs.
                            2004 Impala LS 3.8
                            • ChristianC Offline
                              ChristianC Offline
                              Christian
                              My Capri ran a 12.35 on motor with 311 hp to the wheels and a 12.80 on motor when it only had 245hp to the wheels. You have to remember on Mustangs you can change the gears very easy and they respond to that well.
                              Playtime Performance
                              06 F-150 Lariat
                                Alright, I'll show you my slip next spring when I get some decent tires.
