  4. Junkyard Turbo Setup
50 Posts 14 Posters 2.7k Views
    Why isn't it closed? Because im in charge of it, thats why. So your gonna do your tune on a track w/o datalogging or using a wideband?
    A.) If you have no datalogging your in a world of hurt.
    B.) If your burning a chip w/o any A/F graphs based off the vehicle your in a world of hurt.
    C.) If your buring a chip and just adding fuel on the stock injectors and maxing out the duty cycle your in a world of hurt.
    Why do you keep using Hondata as a refrence? When did Hondata come into play here? IMO Hondata is a watse of fucking $$. By the time you have the unit, romulator, and burner you've put more into the system then you would have just buying a AEM. I would rather be using a AEM than a Hondata anyday. My biggest concern here is where are you getting the fuel tables/timing tables/boost tables from. If you dont have bigger injectors you can just go and add more fuel into the game, your gonna overun the injectors. If you have no datlogging/wideband how are you tuning?
    Honestly here now, i wanna test your chip burning ability. I'll tell you my exact setup and i want you to burn me a chip. I wanna put it on the wideband and see how it does. If you know this system like you claim you do, you should have no problems setting up my fuel/boost/timing tables. Secondly im going to the track next weekend, i'll run your chip vs my AFC and compare them on a track.
      AcesHigh wrote:
      1. Look through Hondata.com for many examples of sub-10 second runs using a chip.
      2. You can hook a wideband to a chipped ECU and datalog to your heart's content.
      3. You wouldn't neccesarily need a dyno, although it greatly increases accuracy. Tuning can be done using track runs.
      Why isn't this thread closed yet.
      Becuase you keep making stupid responses.
        seanjohn
        Any "standalone" (hondata, aem, blah blah blah) is a big waste of money IMHO unless you are running a VERY serious setup. Honda ECU's are capable of running boost, higher compression, nitrous, etc. which the proper map. Do your research and you will find out it is not necessary for even quite a bit over moderate setups.
        Edit One plus side to stand alone is being able to tune 'on the fly' however, in this case its probably well worth its money. In my case I just have a couple chips, one tuned for each setup (track day, street, different jets, etc.).
          Yeah, and you can tune on the fly w/ an AFC as well. You guys are not supporting your chips is so good theory here. And im still waiting for one of you 2 to burn me a chip to test for my car. Idk why its so difficult, i'll pay for the chip to prove the point.
          I know exactly what you guys are trying to do. Your gonna buy some chip off the internet for some setup that is close to what your running on your own vehicle which is fucking stupid. The only reason i thought of running a AEM was to get the 3 bar MAP but its possibly to wire that up now to the stock ECU sop im gonna continue on w/ my "worthless" AFC.
          I'll agree a chip can work but the way most of you are doing them is just stupid. If you don't have the equipment or ability to burn you own chips w/ the tables that suite your car then their just a waste of time. I sitll like the tune on the fly ability of a AFC better though.
            You are not correct on the standalone setups. There is more power to be had even out of a bone stock car. The factory fuel maps are normally pretty rich and pretty tame on the timing maps too. I'm not saying that you will get another 100HP out of tuning a stock car, but you will be able to get something. It's pretty nice being in control over whatever the car is doing.
            So why hasn't this point been done and taken care of yet? All you have to do is burn the chip and Nick will throw it in, run it, and compare the results. Very simple. I will also call bullshit on the chip burning theory you have going on here.
            • AcesHighA Offline
              AcesHighA Offline
              AcesHigh
              I think I've said this about fifteen billion times. Did you even read that post above, or are you totally incapable of that? There WILL be datalogging (accessible via chipping). There WILL be a wideband (accessible via chipping). I cannot burn you a chip based on the mods you tell me. I CAN burn you a chip for a stock car. Many stock maps are available through Hondata. I CAN burn you a chip after a day of testing and tuning. It will involve modifying these maps.
              Hondata IS chipping! That's why I mention it! You obviously have no idea what this whole process involves, so just stick with your AFC powered Diamond Star. As you add on a different turbo, different sized injectors, different compression pistons, your AFC will be your performance bottleneck. So be it.
                I dont have a DSM, i have a 92 civic hatch!
                Nowhere in this thread does it say you have a datalogger/wideband or will be using one. It says you can hook up a datalogger but you never once said you owned it or a wideband. Also in the past thread you guys stated that you kind find chips online for any setup being there are so many different onces out there you can use one thats close. That being said, find me one, i wanna test it out. Can i give you my hatch and you burn a chip for it this week? I wanna test it via live data vs. my AFC tune.
                Oh, and your right, i have no idea how this process works, thats why i've built cars that have went faster and made twice as much power as any of yours, and why we have the fastest 4 cyl's in the state!!!
                • W Offline
                  W Offline
                  Wizard
                  Isn't there a 4-cyl DSM running mid 7s with stock ECU and VPC (aka piggyback) with a GCC (aka AFC by HKS)? Some performance bottleneck. For most street cars, piggybacks are fine. Standalones should be left more to the more serious track-only cars. Constant climate changes, etc makes constant changes with standalone a PITA.
                  Al Blaha ran mid 10s at 132 in his 90 AWD with stock ECU, 1st gen AFC, and the motor never left the car. Drove the car on green DOTs over 3 hours every month or so to run the local import drags.
                  If you want a 3-bar MAP....just goto AutoZone or Advance and buy the GM 3-bar for the Turbo V6 Trans-Ams. $55.00.....not sure if the signal output is the same....but probably is.
                  Wiz
                  1992 GVR4 598/1000 Nile Black
                  1992 Tsi AWD
                  1982 Datsun KC 4x4
                  1990 Laser 2.0 AT NT
                  1994 ES 2.0L NT 5-spd
                    seanjohn
                    Give me your setup - I'll get you a map. It's not that tough, for someone who owns a shop you should be a little better informed. Albeit, I do understand your support of expensive aftermarket parts.
                    This is what I do.
                    Step 1 - E-mail Kenji, give him my setup, he gets me a custom map as close as he can.
                    Step 2 - Take car to Elite (or anyone that knows how to dynotune with hondata, uberdata, crome, turboedit, aem, blah blah blah whatever). They use a wideband or dyno to create/burn maps.
                    Step 3 - Drive car. Spend extra money on waste of cash juiced scooter.
                      This is what I do.
                      You all are the ones mis-informed not nick...
                      If you think back, nowhere did you talk about "step 2" previously. This is the most critical part if you are going to be using chipped ecu's. You cant just slap a chip in that has "roughly" been made out for the car with mods, and then drive it, becuase it simpley will not work. If you hop on the dyno in conjunction with a wideband, I know for a fact that there is no problem with this.
                      You missed the point that this was going to be a chipped car with no wideband or no dyno.
                      Oh and you all are fucking WE-TODD-ED if you think AFC's dont work well
                        seanjohn
                        With a mild setup I think you can skip step two and you'd be "ok". Obviously you won't be reaching your motors maximum potential...but typically they are mapped safe enough that your motor should be safe. I have no experience with AFC, but I have heard mostly bad things. And 8 point 500rpm interval fuel adjustments don't seem like they would exactly do it for me, but again, I have no experience with them. I'll stick with my route, seems to be the cheapest-easiest-most friendly way of doing things.
                        • My NOvaM Offline
                          My NOvaM Offline
                          My NOva
                          what are u argueing about???
                          Hey Tina come get some hamm
                            seanjohn
                            Arguing ? I didn't realize I was arguing about anything. Why, what are you arguing about?
                              by the way afcs are 200rpm intervals
                                seanjohn
                                No...it's 500rpm.
                                  afcIIs i believe are 200rpm
                                    seanjohn
                                    Yep, the II is also twelve point as opposed to eight.
                                    • My NOvaM Offline
                                      My NOvaM Offline
                                      My NOva
                                      told u
                                        seanjohn
                                        My NOva wrote:
                                        told u
                                        Haha, I thought you were just talking about the original. But yeah, you were right.
                                          Haha, you did all this talking up of your chips/tuning up and youir not even the one doing it, bwahaha. Bring it on little man, bring it on.
                                          How about YOU burn me a chip. Your just an internet NOOB who reads the internet then all of the sudden thinks he knowsd everything. You flat out said you have no experience w/ an AFC but yet you bash it, how's this work? Continue w/ your ways of doing it, thats fine but you will always be 2 steps behind. You can run a new AFC and have 200 rpm incrments of adjustability as well as store 2 different maps.
