  4. cage requirements???
27 Posts 10 Posters 1.1k Views
    Forget the cage you need vtec.
      vtec is lame
        MisterCMK wrote:
        vtec is lame
        quoted for the true. but i well make exceptions to this one
          well i might not have vtec.... but we will see
            boosted b20 ftw!
              11.49 or faster - 6 point roll bar required
              mild steel can be mig welded, chromoly must be tig welded
              scatter shield @ 11.49 or faster
              fire jacket @ 11.49 or faster
              extended wheel studs and open ended lug nuts @ 11.49 or faster
              3" wide 5 point harness @ 11.49 or faster
              i ran 11.2 on a walbro 255 hp and stock lines
                Thanks for the info nick. I'm shooting for low 10's if not faster... Hopefully with my new setup i will meet my goals...
                  Isn't it supposed to be an 8 pt roll bar?
                    Actually from looking at the rules only a 5 point is required at 11.49. However almost every entry level kit is an 8 point.
                      Nick, do you know where one can dowload a copy of the NHRA rulebook?
                        Off of NHRA.com.
                          Where? I didn't see it on there.
                            I couldn't find the link on there again, but here is the link for the Sport Compact rule book.
                            http://www.nhrasportcompact.com/2006/rules/index.html
                              Hey Matt, Exactly what set up are you planning on running anyway? Motor, Trans, Turbo, Tuning?
                                i'm guessing b20...
                                  ^^^^your guessing wrong...as always...
                                  motor:
                                  • sleeved b16 bored to 83mm
                                  • je pistons 9.1:1????
                                  • pauter rods
                                  • balenced crank
                                  • b16 head ported/polished
                                  • rocket springs/retainers
                                  • custom intake manifold
                                  • mustang TB
                                  Trans:
                                  • ls tranny
                                  • 4.7 final drive( i think dunno yet)
                                  • liberty gear cuff
                                  • obx lsd (i want to see if this holds up)
                                  • gearspeed syncros
                                  • os giken twin plate unsprung
                                  Turbo set up:
                                  • GT40 (don't know specifics yet)
                                  • custom manifold (equal length and pulse)
                                  • 4" down pipe
                                  • 4" AL exhaust
                                  • huge fmic(thinking about air/water)
                                  • fuel setup???
                                  • aem???
                                  • cop ignition
                                  • cam trigger
                                  Thats all i know for now
                                    Looks like Honda-Tech mod list 101 except on a small bore short deck motor and an LS trans.
                                      I hope that wasn't your way of being clever....
                                        No, not at all.
                                        Starting with a b16 is a good way to shoot yourself in the foot for having a nice torque curve. Maximum displacement on the short deck motor is roughly 1.8L which is going to limit airflow feeding a turbo that large.
                                        I see a lot of parts on the list that don't need to be purchased and can save you money trying to get a fresh build off of the ground and a lot of parts that are not on the list.
                                        What suspension, safety equipment, chassis materials, etc are you planning on using? Tire size plays into gearing which plays into the rev range that you want the car to cross the line at at the end of the 1/4 mile.
                                        What I see is a pretty standard mod list "everybody" follows when they build a setup on H-T these days just with some changes made for parts that you already own I am guessing.
                                          for the price of the B16 shortblock matt couldnt go wrong...i know that much...that's why he's going with it
