  4. AMS oil
AMS oil
19 Posts 9 Posters 1.2k Views
  • JoelJ
    JoelJ
    IMHO if you have anything other than a b series... just stick with normal oil... like valvoline, My CTR made a world of difference when i switched to mobil 1 but a d series isnt worth spending that much on oil...
      Every motor can and will benefit from the benefits of the consistent blend and breakdown characteristics of a good synthetic oil. It will reduce wear, extend motor life, possibly increase gas mileage and (to a degree) lessen our dependance on foreign oil. I am a big AMSoil fan, I have been for years. It is the only motor oil I run in my cars. Not saying Mobile 1 or others aren't good oils, I just have had great luck with AMSoil. Just a thought here though, if you motor has high miles, you will probably want to go with a synthetic blend of some sort for the first oil change and change the oil after about 1k miles (added detergents will clean up the engine and you don't want that crud floating around for 3000 miles) after which you should be safe to switch to full synthetic, but monitor the oil to see how dirty it looks/feels.
      • SmitEvoS
        SmitEvoS
        weshole wrote:
        Ultimately I should have them all analized but for the regular user it is not really necessary.
        analized huh........:drunken_smilie: Quote of the week.
        • JoelJ
          JoelJ
          Not disagreeing with you chuck, but for most people, unless your REALLY into getting all of your 90whp in a stock civic/crx, theres no point in paying 1/3 of what the motors worth to change your oil... If you have the money go for it, maybe think about just changing your oil more often if your have high mileage.
          • wesholeW
            wesholeW
            You liked that huh? Good to see someone caught it. BUTTS
              I've never once thought of oil as a power adder, but rather a motor protection. I stand by my original statement.
              • bubbaB
                bubbaB
                wannabe wrote:
                what motor do you have in your crx?
                It has a B18 in it. I've read that you can get better mileage, get a little more power due to less resistance from regular oil, and better engine protection. And you dont have to change it as often either. I was wondering how true all of these are. I was also planning on using the cleaner before switching over, to get the full benefit of using full synthetic.
                  better mileage=maybe a bit
                  more power=slightly....maybe
                  less resistance=absolutely
                  better engine protection=without a doubt
                  don't have to change as often=if you use AMSoils oil bypass filtration kit, you may NEVER have to change your oil...just add when its low and change filters every 5k miles and send in oil for analysis once a year.
                  • A
                    A
                    adog
                    I actually did a bit of analysis on some motor oils, and the results are contained in the attached zipped spreadsheet. The machine I was using really can't say anything about the base polymers, but additives based on metals can be detected. Probably the most significant difference is the higher Mo concentration in the more expensive oils, which is probably due to more anti-wear additives being present. All of the oils pegged the Zn detector at 300 ppm.
                    oil comparison.zip
                    • RidinRailsR
                      RidinRailsR
                      bubba do you ahve a black crx with altezza tails?
                      • bubbaB
                        bubbaB
                        No mine's dark bluish, black hood, i put stock tails on a couple months back.
                        • JoelJ
                          JoelJ
                          call me about those gauges tomorrow...
                          • RidinRailsR
                            RidinRailsR
                            i use Royal Purple in my dsm and in my honda...and both of my engines like it. plus its purple.
                            • GarageAlchemistG
                              GarageAlchemistG
                              GarageAlchemist
                              We runs Amsoil in all of our sleds and its great! Plus Dan the Amsoil guy is the shit, he comes out to ricer meets.
                              97 GTi, 03 KJ
                              • bubbaB
                                bubbaB
                                Where around here do I find it? I havent seen any stores that stock it (the original), I know Fleet Farm had the low grade AMS back in fergus, but i wouldnt want that.
