  4. AMS oil
AMS oil
19 Posts 9 Posters 1.2k Views
  • wesholeW
    wesholeW
    99slowGSX wrote:
    analized huh........:drunken_smilie: Quote of the week.
    You liked that huh? Good to see someone caught it. BUTTS
      wannabe wrote:
      Not disagreeing with you chuck, but for most people, unless your REALLY into getting all of your 90whp in a stock civic/crx, theres no point in paying 1/3 of what the motors worth to change your oil... If you have the money go for it, maybe think about just changing your oil more often if your have high mileage.
      I've never once thought of oil as a power adder, but rather a motor protection. I stand by my original statement.
      • bubbaB
        bubbaB
        wannabe wrote:
        what motor do you have in your crx?
        It has a B18 in it. I've read that you can get better mileage, get a little more power due to less resistance from regular oil, and better engine protection. And you dont have to change it as often either. I was wondering how true all of these are. I was also planning on using the cleaner before switching over, to get the full benefit of using full synthetic.
          better mileage=maybe a bit
          more power=slightly....maybe
          less resistance=absolutely
          better engine protection=without a doubt
          don't have to change as often=if you use AMSoils oil bypass filtration kit, you may NEVER have to change your oil...just add when its low and change filters every 5k miles and send in oil for analysis once a year.
          • A
            A
            adog
            I actually did a bit of analysis on some motor oils, and the results are contained in the attached zipped spreadsheet. The machine I was using really can't say anything about the base polymers, but additives based on metals can be detected. Probably the most significant difference is the higher Mo concentration in the more expensive oils, which is probably due to more anti-wear additives being present. All of the oils pegged the Zn detector at 300 ppm.
            oil comparison.zip
            • RidinRailsR
              RidinRailsR
              bubba do you ahve a black crx with altezza tails?
              • bubbaB
                bubbaB
                No mine's dark bluish, black hood, i put stock tails on a couple months back.
                • JoelJ
                  JoelJ
                  call me about those gauges tomorrow...
                  • RidinRailsR
                    RidinRailsR
                    i use Royal Purple in my dsm and in my honda...and both of my engines like it. plus its purple.
                    • GarageAlchemistG
                      GarageAlchemistG
                      GarageAlchemist
                      We runs Amsoil in all of our sleds and its great! Plus Dan the Amsoil guy is the shit, he comes out to ricer meets.
                      97 GTi, 03 KJ
                      • bubbaB
                        bubbaB
                        Where around here do I find it? I havent seen any stores that stock it (the original), I know Fleet Farm had the low grade AMS back in fergus, but i wouldnt want that.
