  2. Introductions
  3. Introductions
  4. Hi.
Hi.
26 Posts 17 Posters 1.7k Views
  • G Offline
    G Offline
    gtfourmn
    Hey,
    Just wanted to introduce myself to everyone. I'm from Blaine, MN and attend UND. Never been to ND until this fall, but so far it's been great.
    I drive a subaru and own a civic at home.
    -Vang
      welcome. the subaru stock?
      • G Offline
        G Offline
        gtfourmn
        Subaru is stock.
        I just got it hence the civic is at home. Civic is also stock.
          very clean. you need to post more pics off it
          • sitn2loS Offline
            sitn2loS Offline
            sitn2lo
            welcome
            Yukon Denali on 22's
            • BookemB Offline
              BookemB Offline
              Bookem
              Welcome to Fargostreet, How's the partying in Grand Forks treatin ya?
              Legacy GT
              Gmc Suburban
              Hallorann: Fargostreet?
              Hallorann: No, I ain't.
                Welcome.
                  gtfourmn wrote:
                  Hey,
                  -Vang
                  BOOOST!
                  • ColinC Offline
                    ColinC Offline
                    Colin
                    wannabe wrote:
                    BOOOST!
                    not worth it. JDM Sti engine swap: less cost, less time, more power over a larger band.
                    Beautiful car.....
                      Welcome....
                      • 925JL9259 Offline
                        925JL9259 Offline
                        925JL925
                        Welcome to the site.
                        95 TSI
                          interested in selling the suby this spring? 🙂
                          welcome.
                            Hey, whats up?? i go to UND too....its pretty sweet, im sure you will see me around in the spring when i get my car back out.
                            • 97CL9 Offline
                              97CL9 Offline
                              97CL
                              welcome!
                              :pickle:
                              • G Offline
                                G Offline
                                gtfourmn
                                I think I saw your car once at the Union's parking lot. Nice ride.
                                Otherwise, thanks for the warm welcome everyone.
                                  Beautiful car.....
                                  Can't you just buy stock parts and use those?
                                    welcome
                                    • ColinC Offline
                                      ColinC Offline
                                      Colin
                                      sorry about the thread whoring
                                      ou could, but:
                                      full turbo setup from reputable dealer = 3000+ and makes 230 wheel horse at 19 psi and goes to 7k
                                      full clutch replace and tranny rebuild to handle it = 2500 +
                                      boost control unit = whatever you can find
                                      tuning = same as swap. or price of cobb access port
                                      Biggest drawback is rebuilding for low compression + the 100 hours of work and big lag in turbo setup. generally a straight line only option
                                      Full ready to run JDM "WRX" 2L with 4.44 final drive manual six and mecha LSD makes same horse at 14psi and goes to 8.5-9 rpm safely and uses TMIC and factory low compression setup to full spool around 3k = 4-4500 from a reputable dealer + misc parts + shipping ($500 insured)
                                      ^ almost plug and play. If you switch to JDM ECU full swap on a first time estimated time to running = 23hrs. Then tune with all factory setup
                                      Biggest problem is getting ahold of one because they are bought up quickly and you cash on hand to buy. wait list is like 6months to 2 years for an RA
                                      great autocross setup, turn up boost and get a straight line car.
                                      • ColinC Offline
                                        ColinC Offline
                                        Colin
                                        i just realized you meant USDM Sti parts, i think
                                          I did.
