  4. Evil Knievel was a PUSSY compared to this guy.
21 Posts 14 Posters 1.2k Views
    I got a continental, Anyone got some rockets?
      that was nuts! he should have known it wasn't going to work though.
      • M Offline
        M Offline
        MrScary
        I was surprised it dropped like a rock. Not enough speed I guess
          I'm pretty sure it had nothing to do with the speed, just the pitch of the ramp, and the weight distribution of the car...
          • theobliviousT Offline
            theoblivious
            the bernoulli effect, and pitch.
            BOOST....to be continued
            • M Offline
              M Offline
              MrScary
              Ok now that I look at the vid again, it was aimed like straight up almost
              • GreenLanternG Offline
                GreenLantern
                wow...the 70's obviously didn't account for aerodynamics....
                  I Don't think most cars are engineering to be powered by rockets and jumped off steep ramps.
                    Should have used a Honda and he probly would have done it.
                      HandoEX wrote:
                      This is a video of some maniac trying to jump a rocket powered Lincoln over an 8 story ramp across a river that is one mile wide. Enjoy...
                      http://www.automotosport.info/article-346.html
                      You know that Evil Knievel tried the same thing over the grand canyon, right? Only he was basically riding in the rocket and knew he had ZERO chance of making it. Prior to his jump he told his wife what he wanted on his tombstone and basically said goodbye to his family cuz he was sure he'd die.....he got lucky and didn't miss nearly as bad as he thought he would, he thought he'd hit the water and die on impact, as luck had it he landed on the river bank and lived.
                      (I haven't watched this video yet...at work, can't access it)
                        Mental note
                        Dressing like Bruce Lee will not make you able to jump across a river.
                        • Afsil80A Offline
                          Afsil80A Offline
                          Afsil80
                          LankorDie wrote:
                          Mental note
                          They shoulda gone as Chuck Norris. Or Henry Rollins.
                          -Peter
                          1991 240SX
                          • ColinC Offline
                            ColinC Offline
                            Colin
                            Chuck would kick the car across, while he was in it.
                            Henry would have just eaten the car then jumped across
                              Using the basic physics equation for range, and assuming they built the ramp at the correct angle for maximum distance, and neglecting air resistance, and rounding up both the speed of the car and the height of the ramp, there is still no way he could even come close.
                              • ColinC Offline
                                ColinC Offline
                                Colin
                                I think that the idea was that the rocket engines could fire throughout the flight, propelling him the whole time: would work if it wasn't a car, or a really plane/rocket/projectile shaped car
                                Thinking about it, with a propulsion engine setup, wouldn't the angle of the ramp not even matter. In theory he could generate his own lift. So as long as he started above the level of the water, he could make it??
                                  this is correct if said rocket is propelling him over 200mph and he has something to direct airflow ie flaps and rudders.. which would basically make it a plane and therefore not cool, anyone could fly a sesna over a hole.
                                    if the wings were designed in such a way as to create enough lift, yeah.
                                    just having rockets propelling him the whole time wouldn't make him fly all the way across. the front end would just lift up like it did in the video, and the car would end up doing back flips till it hit the water.
                                    • Afsil80A Offline
                                      Afsil80A Offline
                                      Afsil80
                                      He also would've shat it out and killed every toddler that was in a 10 mile radius of the event.
                                      -Peter
                                      1991 240SX
