  4. new turbo and pregress pics
26 Posts 10 Posters 2.5k Views
    what is it going on?
      I'm guessing by the pics of the motor, its a GTO 🙂
        oh, no the GTO is long gone, this things going in the Buick. 6.0L and a 4l80e is a pretty stout drivetrain, the v6 just has its limits, at around 600whp then you need to step up to the big Stage II block and thats expensive as hell, this stock motor with the turbo is good to about 550-600whp, then a set of rods and pistons with good bolts makes it good to around 1000whp, for about 1/4 the cost
        Gary
          is it built?
            Damn, that thing is gonna be badass in the Buick...
              jus the cam for now, like i said, 500-550whp is more than enough this year, im not even gonna paint it up till next winter, want all the bugs and shit worked out of it first. Want to do some interior and body work before i go for a 1000hp motor. still dont think im gonna put a bar in it so wont be going to the track much, thats why i went with the 4l80e, should get in the low 20s for milage, i got 24 with the GTO on the highway, similar weight and gearing.
              Gary
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                Daaang. That thing is big!!
                • blindsp1B Offline
                  blindsp1B Offline
                  blindsp1
                  nice as hell turbo!!
                  New Bike: 08 zx-6r FOR SALE
                  05 Yukon
                    Gary do you smell that???..........smells like pussy,
                    more like sex lol
                    Give me a 200 shot and a another rotor and i might spool that..... at least i still get frist ride....
                      Looks good man! Hard to tell from the pics, is it a T4 or T6 turbine housing? Can't wait to hear how it works for you.
                        hey dave, you see that you aint got shit on me! no but yours aint much bigger than mine. best part is for 450$ i can upgrade to a 80mm which is good to 1250hp, or an 88mm which is good to 1400hp. but, 1076 is more than enough for me. anyway thats a t6 all the way. it makes a gt42 look like a sissy girl. but you and me both know gt42's are for pansies!. haha.
                        Zack you need a 4 rotor p-port to even think about spooling that, you just stay with your wussy little t-4s and get ready for a ass whoopin!
                        Gary
                          Gary
                          talk shit after you run a 9.46 or lower!
                            GT4788 is bigger than that s400...
                              I think your talking about either a GT4708 or GT4718, there is no such thing as a GT4788, because that would be a tiny compressor with that big of a turbine
                              GT4708 108mm Major 80.7mm Minor
                              GT4718 117.6mm Major 88mm Minor
                              S400 105mm Major 75mm Minor
                              Your right that either GT47xx has a larger compressor, but the turbine is larger
                              on the S400
                              S400 95mm Major 86 Trim
                              Gt47xx 92.7mm Major 82 Trim
                              Either way the S400 is going to respond faster than the GT47 even with the larger turbine because of the comp/turbine ratios.... even though the GT47 has a smaller trim to help spool, yet the smaller trim hurts topend flow compared to the S400...with comparable turbine ARs
                              the S400 will run out of compressor a good deal before though
                                It's a GT4788 is the other name for the GT4718 IIRC.
                                88mm compressor inducer
                                  Its so fucking stupid...the difference in the naming between the old T series and the new GT series
                                  Using the Compressor Major to name the GT's and the Compressor Minor to Name the old T series....It makes a person very confused if you are not aware
                                  and the GTXX only denotes the turbine frame size.....whatever i guess
                                    Yup. Borg Warner S366 for me this year hahaha.
                                      Na Ftw!
                                        yeah the new naming system is gay. one thing people forget is that you make as much of your power on the exhaust side as the compressor. case in point, a gt35 may be rated for 750hp, but it has such a high pressure turbine, most people never see it. step up to a gt42 with the same compressor, and the 750hp becomes attainable fairly easily. now as far as big turbos go, these new designs flow so much better than the older bigger ones. specifically this 75 mm is the repacement for the TV8101/8102. the 8101 was an 85mm compressor, and a bigger, heavier turbine. this new 75mm will keep within 10lbs/min of that old one, and spool is around 800rpm sooner, with a broader efficiency range. also the 80mm upgrade is $240, and then it actually exceeds the old 85mm a hair. This s400 is the same turbo that Innovative uses for its $2000 dollar GTB 88. and i can have the same thing for a little under $1200. Turbo companies are ridiculous in their markups. Heres the map for the 75mm compressor. Ive never seen a map that wide and flat before. Man you can beat the pricing on these Borg Warner turbos, its really making it easier for alot of these guys to build bitchin setups on a budget. Also i was looking at a gt42/47 based turbo, but it uses a high pressure turbine, more suited to high rpm, small displacement engines, and is a real choke point on these bigger v8's. the big turbine is also very kind to the tires as boost is very controlable with the throttle.
                                        That s366 should be a nice addition to your ride, now if it was right wheel drive you might be able to do something with all that power! Hope your driveline holds up for awhile this year.
                                        The rest of my fuel system stuff came today, aeromotive filter, -8 and -6 fittings and braided hose. can plumb this thing in now and see if my wiring works, hopefully be able to turn it before christmas and see how much shit i f-ed up on this wiring.
                                        Gary
                                        Gary
                                          BW does some interesting stuff. In garrett terms, your turbo is basically a GT4276 on the compressor side, and a GT47 on the turbine side. Should work ok with your big cube motor, I'm looking forward to seeing a dyno to see how it spools for you, etc. What a/r are the housings?
