boosting a G6
anything can be boosted, but on that i would assume it would all have to be custom....bring it to SLS and hand them a credit card...
http://www.g6performance.com/forum/
Thats a G6 forum. It should have everything your buddy needs.
tell him to buy this kit....im sure he could make it work somehow..
http://www.pfyc.com/pc/WB3039/MCUNDER/Cartuning+Performance+3.8L+Turbo+Kit.html
97slowgsx wrote:
tell him to buy this kit....im sure he could make it work somehow..http://www.pfyc.com/pc/WB3039/MCUNDER/Cartuning+Performance+3.8L+Turbo+Kit.html
it could be done but would need all new pipes and the engine bay is differant, it would be a good start as far as ideas. it is supposed to bolt on to the stock exhaust right?
97jeep wrote:
it could be done but would need all new pipes and the engine bay is differant, it would be a good start as far as ideas. it is supposed to bolt on to the stock exhaust right?yes, im sure the exuast manifold is the same...its probably the same block....the engine bay is different...but pipes can be cut..and rebent...
97slowgsx wrote:
yes, im sure the exuast manifold is the same...its probably the same block....the engine bay is different...but pipes can be cut..and rebent...They aren't the same block at all. In fact, it's actually a newer udated version of the 60degree GM V6(2.8, 3.1, 3100, 3.4 DOHC, 3400) and it has variable valve timing. They are actually the only cam in block motor with VVT...
It would not be hard to make a crossover turbo kit.
