  4. 98 Chevy Silverado
98 Chevy Silverado
28 Posts 13 Posters 1.4k Views
    Does it stay running when it dies? What exactly did yo have done to it a Nat'l muffler. It sounds to me like the fuel pump is being shut off by one reason or another. Possibly even being the passlock/passkey security in the vehicle. But more info is needed.
    • lord_deastofactL Offline
      lord_deastofact
      well I know my roommate had a 98 silverado and had alot of problems like that. the fuel pumps are shit, he went through a few and also had a problem with one of the relays or fuses in the engine bay, it would cause the truckto not start.
      Minute ricer!
      • 91nbtsi9 Offline
        91nbtsi9 Offline
        The fuel pump has nothing to do with the engine cranking though. Have you checked all your ignition fuses?
          sounds like an ignition problem personally thats what happened to my civic. It would start and then run for 2 hours or so, then die randomly. and it would slowly lose RPMs when it died, I thought it was "gasping for gas" as you say, too. But the gas pedal didnt do anything.
          • JN607J Offline
            JN607J Offline
            JN607
            I agree with the above few, check your fusible links, maybe a solenoid, and replace the fuel filter. Just as a precaution, make sure your Battery posts are clean to because my ford used to do that. Sometimes those battery posts get so corroded, the power doesn't get through the corrosion so you have to clean them.
            2004 Scion xA
            Airman First Class Nelson
              JN607 wrote:
              make sure your Battery posts are clean .
              Coke ftw!
              • Turbo5OhT Offline
                Turbo5OhT Offline
                Turbo5Oh
                ok before u get all crazy here start off with figuring out the starter problem
                start at the starter, check for batt. voltage at the solinoid the ( the bigger post on the starter solinoid )
                u should have the same voltage at the solinoid as the battery if no or very little voltage there is a problem between starter and battery
                then (this will require another person) using volt meter or test light find the small wire coming off the solinoid (i think its purple) have ur test light to that and a know good ground and have somebody try to start it u should have close to batt power at the small wire when somebody tries to start it or it will light the test light
                if there is no signal to the little wire when cranking then u probly have a ignition switch problem
                after u check the starter out let me know and i can continue to help if u want
                • BookemB Offline
                  BookemB Offline
                  Bookem
                  I can hook up my scan tool if you'd like, no charge. also can you hear the fuel pump run with the key on, engine not running?
                  Legacy GT
                  Gmc Suburban
                  Hallorann: Fargostreet?
                  Hallorann: No, I ain't.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    A scan tool isn't going to help anything...
                    Listen to Schell. If you have no crank, you have an open somewhere in your ignition circuit.
                    • BookemB Offline
                      BookemB Offline
                      Bookem
                      A scan tool might show why it is shutting off after 30 seconds, My suburban was doing that and a code for the ignition module came up, I talked to a guy at sellands he said that would cause my the faults i was having, also a new pick-up coil would probably be needed. Replaced one part at a time and he was right. Point being the scan tool saved me almost a hundred dollar charge to read the code and who knows how much to tow it there.
                      Legacy GT
                      Gmc Suburban
                      • Turbo5OhT Offline
                        Turbo5OhT Offline
                        Turbo5Oh
                        gm security stuff is kind of dumb sometimes if the car is started with out the key i.e. jumping the starter the computer will see that there no ignition switch signal and shut down the injectors or spark so that would explain why after jumping the starter that it runs for a few secs
                        figure out the starting issue first or else u be chasing multiple random problems all day, i do this for a living and i know how to save some headaches
                          I know how to fix the problem...........
                          Sell the truck and get a FORD 🙂
                            Excellent advice Schell, if you want to check voltage at the ignition (key) switch, here are the colors
                            12volts red +12Volts ignition harness (Constant Power)
                            Starter yellow or purple +12Volts ignition harness (Power ONLY While Cranking)
                            Ignition pink +12Volts ignition harness (Power When Cranking & While in the "Run" Position)
                            Second Ignition white +12Volts ignition harness (Power When Cranking & While in the "Run" Position)
                            Third Ignition pink/white +12Volts ignition harness Notes: The pink/white does not exist on all models. (Power When Cranking & While in the "Run" Position)
                            • JN607J Offline
                              JN607J Offline
                              JN607
                              AGREED!!!! ^^^ Lol...
                              2004 Scion xA
                                w00t! Quoted for truth! 😄
                                  first... ur gay. ur stang looks like ass. you go /cut wrists :icon_rr:
                                  second, it was the starter relay in the fuse relay box under the hood. for some reason, it got really loose. Fixed that, and it started no problem. but the gasping for gas still was an issue. so i went and bought a fuel filter, put it in, and BAM BITCH, SHE WORKS.
                                  So yep, she workin' good now.
                                  thanks guys.
                                  • 94LS9 Offline
                                    94LS9 Offline
                                    94LS
                                    fuel pump for sure my dad had the same problum with his tahoe 2 times, happens to all chevy trucks
                                    94 Acura Integra, ls/vtec build
                                    02 Jeep Grand Cherokee, lifted! daily driver
                                    87 Jeep Wrangler moster jeep!
                                      I love how 20 minutes after someone posts the problem, someone else comes in and says "I KNOW its gotta be this problem".
                                      heheh...n00bs
                                      • 91nbtsi9 Offline
                                        91nbtsi9 Offline
                                        LOL wait to call it man.
                                        I like how all you guys just have hunches and think that's what has to be wrong.. You could make some good money in the auto service industry...throwing parts at cars:icon_rabbit:
                                          Nope. FP is fine.
