98 Chevy Silverado
Turbo5Oh wrote:
ok before u get all crazy here start off with figuring out the starter problemstart at the starter, check for batt. voltage at the solinoid the ( the bigger post on the starter solinoid )
u should have the same voltage at the solinoid as the battery if no or very little voltage there is a problem between starter and batterythen (this will require another person) using volt meter or test light find the small wire coming off the solinoid (i think its purple) have ur test light to that and a know good ground and have somebody try to start it u should have close to batt power at the small wire when somebody tries to start it or it will light the test light
if there is no signal to the little wire when cranking then u probly have a ignition switch problem
after u check the starter out let me know and i can continue to help if u want
Excellent advice Schell, if you want to check voltage at the ignition (key) switch, here are the colors12volts red +12Volts ignition harness (Constant Power)
Starter yellow or purple +12Volts ignition harness (Power ONLY While Cranking)
Ignition pink +12Volts ignition harness (Power When Cranking & While in the "Run" Position)
Second Ignition white +12Volts ignition harness (Power When Cranking & While in the "Run" Position)
Third Ignition pink/white +12Volts ignition harness Notes: The pink/white does not exist on all models. (Power When Cranking & While in the "Run" Position) -
MisterCMK wrote:
w00t! Quoted for truth!
first... ur gay. ur stang looks like ass. you go /cut wrists :icon_rr:
second, it was the starter relay in the fuse relay box under the hood. for some reason, it got really loose. Fixed that, and it started no problem. but the gasping for gas still was an issue. so i went and bought a fuel filter, put it in, and BAM BITCH, SHE WORKS.
So yep, she workin' good now.
thanks guys.
I love how 20 minutes after someone posts the problem, someone else comes in and says "I KNOW its gotta be this problem".
heheh...n00bs
skatingreo1 wrote:
fuel pump for sure my dad had the same problum with his tahoe 2 times, happens to all chevy trucksLOL wait to call it man.
I like how all you guys just have hunches and think that's what has to be wrong.. You could make some good money in the auto service industry...throwing parts at cars:icon_rabbit:
skatingreo1 wrote:
fuel pump for sure my dad had the same problum with his tahoe 2 times, happens to all chevy trucksNope. FP is fine.
but its fixed... so thats not it
lol.
