Honda Parts. Step Up the Game
still for sale.
b17 head ported and polished w/jge valve springs. mostly complete head. bout everything you need..no stock cams $600
Crower stage 2 cams $300
STR cam gears $50
DC cer. coat Type R header pratically brand new $200
CTR crank pulley 2lbs. stock gsr is 10lbs. brand new $50
Carbon Fiber top fuel power chamber intake w/ k&n filter $75
Blox b17 intake manifold w/injectors andebay special fuel rail and fuel preasure reg. $125
Type R throttle body w/ sensors $100
NKG wires $5
Hondata intake gasket $10
ls crank good. $20
misc ls blocks,pistons,rods,all prices are best offer. someone buy this stuff. would make a kiler n/a setup.
I have decided to not finish my ls/**** swap in the civic. So here are some of my parts for sale.
Most of this stuff is new, good shape.
let me know what you want and we can go on prices from there.
Other misc. B and D honda parts -
do you have a throttle cable i can get fom ya. whats the goin rate for the b17 head
Civic sold
Bottom end Sold
Cams and gears sold
still have header,ctr pulley
complete top end minus cams
have other misc honda engine parts. rods, cranks ect. -
Yea i have a mostly complete D. ran good when i took it out
soo...... -
also do you have the plate to hold the clutch cable
Ah head is still for sale for $600. its been port and polished and has JGE valve springs. rated for 14mm of lift and 12,000rpms.
Type R header still up for graps for $200
Meizeire electric water pump. paid 350 brand new. let it go for 300. HCI mag. installed one on a b16 and got an average of 10hp and most of 12 throughout the power band i have the mag.
CTR Crank pulley. $50
Cams and gears pending sale. if not will let both of them go for $350
Good ls. head with low miles. BO.
Skunk 2 single bend short throw with Skunk 2 knob. $75ah the i think the Its a D15Y7 if that makes sense.
sent multiple PM's no reply?
he doesn't get on here too often, i will try to call him tomorrow and tell him to check
bump
do you have a b18 ls bottom end???
Adam call me sometime or i will give you a call, you should buy my car now that you sold the civic.....i would even think about taking a couple things for trade depending on what you have left......
