  4. Anyone install sleeves?
15 Posts 5 Posters 1.2k Views
    seanjohn
    tjamz wrote:
    No idea what is involved w/ sleeving. Brian @ Sturdevants seems to be a very good machinist as quite a few people seem to be using him for their headwork and any other machine work, I'm not sure if that is who SLS is using, but that is who I'd go to.
    Thanks, I'll keep him in mind. Wonder what this is going to cost me?
    • RaiderR Offline
      RaiderR Offline
      Raider
      i have sleeved hundreds of cylinders when I worked at a Ford Reman factory...all you do is just cut the opening large enough and leave about 4 thousands less.. and we would put the sleeves in liquid nitrogen and then put lots of locktite in the hole and drop the sleeves in..after that we would bore them to whatever size needed..takes time because u have to make 3 cuts on the cylinder walls and then make a final cut on new sleeve and then you have to hone the cylinder
      POWERD BY
        Roughly $100/ hole plus sleeves.
          seanjohn
          $100 per hole...damn. So what, I'm probably looking at about a grand total...maybe a little less?
            Depends on what sleeves you go w/. I know he can get DART and he also mentioned there is a compnay called LA Sleeve that manufactures a lot of aftermarket sleeves for repairs that supposedly has a Honda sleeves now too. IDK what he wants to charge full done. Mine should be done here pretty quick but he was doing it for no charge as guinea pig.
              seanjohn
              I know you can buy bensons and dartons for about $500 if you find a good deal. I'd like to hear how yours do after a couple thousand miles of boost. Keep me updated for sure. Would he warranty any work?
                you're never going to get someone to warranty a high performance engine...
                  seanjohn
                  Exospeed warranties their sleeved blocks against cracks and sinking.
                    ohhhh.... against sinking... that makes sense... I thought you meant if they were to assemble it...
                    I would say your best bet would be to hit up Tufte with questions, he seem to has a good working relationship with them[email protected]
                      Alright, i got some more info squared away today but no finally pricing set yet until we get my block done and see exactly what its gonna take. But more or less w/in the next month it should be done and we should be able to get sleeves done locally. We will be using Darton sleeves. The offer a closed deck design and then the thick wall open deck design. Lookin as if the open deck will be about half the price of the soild deck. Their saying closed deck is good for 40psi and the thick wall open deck good for 20 psi.
                        seanjohn
                        PSI2HI wrote:
                        Alright, i got some more info squared away today but no finally pricing set yet until we get my block done and see exactly what its gonna take. But more or less w/in the next month it should be done and we should be able to get sleeves done locally. We will be using Darton sleeves. The offer a closed deck design and then the think wall open deck design. Lookin as if the open deck will be about half the price of the soild deck. Their saying closed deck is good for 40psi and the thick wall open deck good for 20 psi.
                        This is info from darton themselves? What prices did you get quoted on just the sleeves?
