  4. wet sanding...
wet sanding...
10 Posts 8 Posters 681 Views
    anybody on here good @ wetsanding? i dont trust myself with it...i'll buy someobody a meal anywhere they want in town plus pay for the paper and stuff if they help me out...on my EK there's some clearcoat drippage and it needs to be wet sanded down. thanks for the help!
      wetsanding is easy. It's really hard to overdo as it only takes off very little at a time.
        weshole wrote:
        wetsanding is easy. It's really hard to overdo as it only takes off very little at a time. Unless he uses 150 grit or something. :bom: Use some 1000 or 1500 grit and a block and it's pretty easy.
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          just watch ur edges you can burn threw them easy... and like dave h said start with 1000 grit then 1500 buffs out easyer
          1976 Chevy K5- lifted beater
          • R Offline
            R Offline
            rustychevy
            Make sure the car is clean, you don't need to be sanding rocks into the paint.
            I usually finish up with 2000 grit, but it's white so it'll be hard to notice if a few scratches don't get buffed out. Also, if the runs are really bad you can carefully use a razor blade to scrape them down. Good luck.
              Someone do it, then make him take ya to Seasons 🙂 $100 Pork Chop 🙂
                aliengotpsi
                I would start with 1000 grit on the drips but the rest 1500 then 2000 then 2500 then 3000 for a final sand and that would make buffing easier.. also its nice to use alot of water w/ soap..
                Meguiars sells 2000, 2500, 3000 grit
                Kevin Smith
                Straightlinedetailing.com
                  alright kevin...so i take it that's what you guys will do when i bring it in? start out with 1000 and work your way to 3000...bc when it comes to body work...i just dont wanna fuck something up myself to the point where it winds up being worse than it was before.
                  • thurmanmermanT Offline
                    thurmanmerman
                    you can always put a NOS sticker over it
                    > Parker;299126 wrote:
                      .......adam, rice?..naw:rolleyes:
