  4. saw my old 300zx na driving round last night
57 Posts 22 Posters 2.3k Views
    Those kind of swaps require more then mechanical know how. You need to research what wires have to be spliced together to get things to work.... what parts you need like differant motor mounts, tranny mounts, driveshafts, wiring..........
    have you looked into the swap before? like researching what all needs to be done?
    You might be better off just swapping to a new car. If you have worked on that car under the hood you well know why.
    Also where do you plan on finding all the parts to do that swap for 2k. on 240's it cost over 300 for all the parts to do just the 5-speed swap. Z32's are extremely hard to find in this area. I have trouble finding 240 stuff and there is more of them. The JDM swaps are going for over 2k. I found 1 under that price but need a tranny. and a used 5-speed z32 tranny sells on the 240 sites for well over $500
      Ricers never look into that stuff. They are all talk and no action.
        Fucking ricers.
          z32 swaps can be found for under 2k with a wiring harness.....and im sure his dad wont have a problem installing it!
            I'm gonna dispute the body kit thoughts. Look here and say what you think.
            Before
            After
              it all depends on the kit and the car wes....but ur car looks alot better with the kit.....it looks like a catfish stock.
                I think bodykits can make a car look great if the right one is chosen. Wes's car is a great example, as is the red Ground Assault S2000.
                  I am not questioning the mechanical ability. It just when doing swaps like this, if you dont research it you might not know that you have to splice this wire to this wire to get something to work. nissans are not like hondas, not all the wiring is almost plug and play.
                  at the very least make sure to get a fsm for both the turbo and not turbo versions.
                  Also you forget the price of the brake and clutch pedals, all the shift boots and seals, clutch master and slave cylinder lower wiring harness, and other things that go along with the auto to five speed swap, or the motor swap.
                    okay i was only referring to the motor...tranny will be another $1k too im sure.
                      Please cease posting in the thread and making yourself look dumb.
                        so then did you mean just the motor? then you need all the other stuff like manifolds, turbos, ICs, wiring........
                        • C Offline
                          C Offline
                          CivicEX7777777
                          Hey Kevin Your car will look nice with the air ride/kit in my opinion!!! TT will also be sweet : )
                          2007 Pontiac G5
                          2007 Yamaha C3
                          2002 Oldsmobile Alero
                          1994 Nissan Sentra
                            okay...motor swap...including manifolds, wiring, turbos ect...i didnt think it was that hard to understand FUCK
                            cmk...get a life outside of fargostreet PLEASE
                              😄 Its not, By swap people normally assume motor, tranny, all the wiring, and other electronics.
                                Why are you still here?
                                  depends on what kinda SWAP your talking about.
                                  cmk...why dont you get laid?
                                  • sitn2loS Offline
                                    sitn2loS Offline
                                    sitn2lo
                                    ha ha good shit
                                    Yukon Denali on 22's
                                      already did, why do you ask?
                                        ok shoulda specified....laid by a girl...and under 140lbs.
                                          SilverZ wrote:
                                          i did not, and i am actually going to just go with the tt engine swap. change out the engine and tranny (to a 5 speed), all in all it will probably cost about 2g... im debating between that, & air ride and a bodykit (bomex). im thinking the tt because it would be cheaper, but i will eventually do both
                                          cool I own a tt. I wish you lots of luck with the swap. If you need to use my car as a exsample Im willing to help you out. I think the supercharger would be killer. But its up to you its your car not mine anymore. Have cops been harassing you about the tint? FPD went out of his way to pull me over and tell me about that tint.
