  4. launching AWD?
launching AWD?
20 Posts 16 Posters 2.1k Views
  • SmitEvoS
    SmitEvoS
    rev to 5500 rpm's and drop the clutch 🙂 You will take off like a bat out of hell.....
    • 2slo50h2
      2slo50h2
      2slo50h
      http://forums.nasioc.com/forums/showthread.php?s=&threadid=587096
      Yes it is a link to a Subaru Imprezza Forum, but if you read through it should give you more than enough info to get you started on how a transmission works and not only how to launch but what causes transmission failure, and a better understanding on the parts that do fail inside.
      • 24valvenotak2
        24valvenotak2
        MisterCMK wrote:
        Shut up.
        Its the same as launching any car except you can launch at higher RPMs because you are putting power to 4 wheels. Naturally there will be more of a risk of breaking parts the harder you launch.
        Now go home and cease posting.
        your an idiot period
        63vette;288530 wrote:
        • InstigatorI
          InstigatorI
          Instigator
          What he said, hell you can even rev higher...
          -Eric
          Playtime Performance
          '91 Honda Accord - DD
          '09 Honda Ruckus - Matte Gray
          • MisterCMKM
            MisterCMKM
            blah blah blah
            thrash;315544 wrote:
            Ford is back :)
            • ParkerP
              ParkerP
              slip it, then drop it..... remember brian were talking to noob's here..... you tell them to drop it..... they will do a 5500+ rpm clutch drop, and i really dont want to here about how he went out trying to lauch his car and took out first gear.....
              BlueSRT0483;244555 wrote:
              Trafik Jamz;260984 wrote:
              You are right Parker.
              • integra_gsr98I
                integra_gsr98I
                I'd rev it to 8000 and side step the clutch!
                  I vacuum lock the brakes, rev to ~5200 RPM and then take my foot off the brake when the last light goes yellow. Works great, I often launch at 19-22psi.
                  btw, I have an auto, not a manual, that might make a bit of difference I'd guess. But then again, you weren't very specific.
                  • treimcheT
                    treimcheT
                    I would also do this.
                    • JoelJ
                      JoelJ
                      Lols and GSR and troy. I agree w/ u 2!
                      • GarageAlchemistG
                        GarageAlchemistG
                        GarageAlchemist
                        yes, slip would be the key
                        97 GTi, 03 KJ
                        • ParkerP
                          ParkerP
                          derrrrr...
                          • RidinRailsR
                            RidinRailsR
                            fuck that...i put the power to the rear and drop that bitch..:)
                            • Sweet-WRX-LovinS
                              Sweet-WRX-LovinS
                              Sweet-WRX-Lovin
                              ^^ That's what you would do if you had a REAL AWD tranny mwuahahaha, jk man. I leave mine on auto, rev the living piss out of it and slip/drop (hard to describe, not a full drop, but hardly slipping at all) the clutch while at the same time mashing the gas. I control the launch/tire slip with the clutch not the gas. 1.71 60 ft on stock tires so far and getting better....slowly, just my opinion and technique.
                              One time...
                              • RidinRailsR
                                RidinRailsR
                                put it in LOCK mode...then do it...your 60 ft would be 1.5 then 🙂
                                • Sweet-WRX-LovinS
                                  Sweet-WRX-LovinS
                                  Sweet-WRX-Lovin
                                  For some reason (could've just been the track conditions the very few days I have run) I was getting better 60 fts with it on AUTO instead of LOCK. Going to have to do some more experimenting eventually with that though. Oh yeah, put it in LOCK and try to turn, it doesn't like that very much hehe. Sorry done whoring now.
                                  One time...
                                  • A
                                    A
                                    aliengotpsi
                                    Well there are a few ways of launching..
                                    1. 2-step (Stutter box) Build's some boost on the line w/ the clutch pushed in. Go to the line try to preload the drivetrain so there isnt a harsh engagment on the drive-train parts( Axles, t-case, rear end, 1st gear) Then once you have pre loaded you will have the car in 1st gear w the clutch pushed in and the gas floored as the car boost builds and the light turns green. you will let the clutch out a little bit till its grabbing then let it out quickly w keeping your right foot planted on the gas... This should light up all 4 tires and shouldnt bog. This will take some practice and id practice on wet grounds befor you take it to a sticky track.... My .02
                                    2. NO 2-step I dont hold the revs at a any certain rpm.. I kinda pulsate the gas peddle fast so the rpms are between 5500-6200 then with a quick slip-n-drop the car will lauch and hopefully wont break anything..
                                    Practice on a dusty/dirty or wet road!!
                                    Thats how I launch I had decent 60-foot times... best of 1.65 shitty tires, I know Nate Burgess had a 1.58 but with AEM and like 15 lbs on the line?
                                    Good luck Newbe
                                    Kevin Smith
                                    Straightlinedetailing.com
                                    • PSiedTSiP
                                      PSiedTSiP
                                      Best thing I ever heard to learn how to launch was simply this: "Weight transfer like a biotch" combined with the technique #2 above. Sound familiar Kevin? 🙂
                                      spanish-rice;237125 wrote:
