  4. Adjustable FPR on NA engine?
18 Posts 8 Posters 777 Views
    Adding more fuel w/o air would make no more but just give you bad gas mileage... adding more than what your ECU is tuned for means bad gas mileage and no more, maybe even less power.
      Maybe you should invest in some cams Paul?
      • 3_Series3 Offline
        3_Series3 Offline
        3_Series
        What I would really like to do is get M3 cams and the Conforti chip specifically tuned for them, but thats like $600 right there. If I had the money I would go with Sunbelt cams + valvesprings = 9600rpm on stock lifters, all for only ~$2700!
        [QUOTE=]Sunbelt Performance Engines, the leading name in BMW engines for the SPEED World Challenge racecars now has now released a 325 2.5L specific version of their Sport Cam set. The E36 215 Sport Cam was created using the most modern design processes, resulting in a product far superior to any other on the market for street and race engines alike. The high lift profile opens the door to new levels of power. Extensive attention to lobe shape allows the engine to rev safely to higher RPMs than seen before - with stock pistons and valvetrain, street or track (more information later). The powerband extends to the higher RPM range to make full use of this capability, but does not sacrifice low end torque.
        Cams sold in pairs only to fit US 2.5L M50 Vanos E36 325 engines (1993-1995).
        Gross cam lift: .411
        Seat duration: (@ .004 hyd lift) 260.0 deg
        .050 duration: 218.6
        Lobe center Int: 114.0
        Lobe center Exh: 116.8
        Max RPM oem springs: 8000 rpm
        Max RPM race springs: 9600 rpm
        [/QUOTE]
        2002 Subaru Legacy
        1993 BMW 325i (sold)
          slowvo
          either turbo it or leave it stock
            drive it off a cliff
            • 3_Series3 Offline
              3_Series3 Offline
              3_Series
              I have an eprom on the way and maybe some pullies down the road, but thats about it. As to the two options, we don't all have the money to go turbo, and still want to mod our cars. I wouldn't say its quite that simple.
              2002 Subaru Legacy
              • 3_Series3 Offline
                3_Series3 Offline
                3_Series
                Thank you for the positive contribution to my thread, now please:
                2002 Subaru Legacy
                  no, I will continue contributing. You should put cams in it and get it tuned so you can get more speed when drive it off a....
                    Coming from a guy who owns a Mustang..
                    • z31Z Offline
                      z31Z Offline
                      z31
                      3_Series wrote:
                      This may be a stupid question, but is there any performance benefit to putting an adjustable FPR on a naturally aspirated engine? i.e. is there much tuning that could be done? I wouldn't think so, as unlike a turbo setup there is no large increase in volume of air into the engine creating a need for more fuel, but still the question remains.
                      Sorry if this is a stupid question. I had a BEGI rising rate fuel pressure regulator ($250) worked good for me.
                        slowvo
                        How much faster is it really going to make it?
                        and what would a rising rate fpr do on a N/A car?
                          I just own a car that sits in the garage all the time. 😄
                          • 3_Series3 Offline
                            3_Series3 Offline
                            3_Series
                            1. Probably not all that much, but all I'm looking for is some more horsepower for a daily driven car, not looking to go 12s.
                            2. edit: nevermind
                            2002 Subaru Legacy
                              What gains did you get out of this, I'm quite curious? The omly thing I see a Rising Rate FMU good for is when you are turboing a car and are a complete cheap ass, or have no other option for tuning.
                                Every good fuel pressure regulator is rising rate. My Aeromotive is a 1:1 rising rate FPR.
                                  I guess I shouldve stated when you are ONLY using a FMU as tuning, not in addition to your tuning...
                                    Ya, I have a 1:1 FPR also.
                                    FMU's should go in the trash!
