92 civic hatch
would u be willing to part with just the dizzy and the p28 w/o the rest of the mini parts??
The JDM ZC came in 2 variations. One is obviously DOHC and the other SOHC...You CANT put a SOHC head on the DOHC block. you can put any SOHC head on the SOHC bottom end. The SOHC ZC bottom end is IDENTICAL to a D16A6 bottom end.
blindsp1 wrote:
just browzing thru wut all u said and i noticed SOHC zc motor....sorry but the zc is the one and only dual cam d-series...just thought i would let u know.GarageAlchemist wrote:
he obivously swapped a SOHC usdm head you noobboth of you are n00bs...there's no USDM involved at all. The JDM ZC came in 2 variations. One is obviously DOHC and the other SOHC...You CANT put a SOHC head on the DOHC block. you can put any SOHC head on the SOHC bottom end. The SOHC ZC bottom end is IDENTICAL to a D16A6 bottom end.
That motor is straight up JDM y0
f'ing n00bsauce
notice the edit in the above post ^^^ haha...n00bs that have to copy Torbs...that's sad
ok with all the retarded info geting flung around in this thread i thought you should know that the jdm zc came in more then 2 different variations....:eek:
one was a sohc non-**** motor like the usdm d16a6 just with a bigger cam and some other lil differences. then there was the dohc zc witch is similar to the 88-89 1 gen integra d16a1. then there is the sohc **** zc called the d15b pretty much a 1.5 L d16z6.... There are also carb versions or both the dohc and the sohc non-**** motors in japan.... so hah...:icon_thumright:Oh and torbert you can put a dohc zc head on a sohc block... it is just there are some oil passage ways that do not line up perfecly so ppl will blow the head gasket almost instantly......
Trade for another civic?
thanks for clearing all that bs talk up matt!
1990TSI wrote:
nope sorry it all goes togetheris that all the mini stuff?? or the car+the mini stuff??
